STARTER REMOVAL -HELP
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
I am replacing the starter in my 87 Iroc 350. Can't get it out from the car. Do I have to remove the bolts from the exhaust y-pipe and lower it to get the starter out from the bottom of the car? (hope not) I am all ears! THANKS JIM
Re: STARTER REMOVAL -HELP
Not necessary...
Point it nose down, rotate it so the solenoid is toward the front of the car.
Might help to take out the #6 & #8 spark plugs.
Axle/Gears: Stock
Got the starter out today. New one in and car running again. It was a SOB. Thanks for the tip from member sofakingdon. Jim
