quench, compression ratio pcv clearance, and me.
Old Aug 29, 2014 | 08:46 AM
truckerz's Avatar
Car: 1989 Formula
Engine: 355ci HSR SBC
OK, FINALLY got all the parts and am ready to put things together. My concern is that when I calculated CR, it was at 11.5/1.... A bit high. Am I missing something? Here is what I have.
A 0 decked standard sbc 350, .040 felpro head gaskets that match bore diameter, 5.7 inch rods. 3.48 stroke, 64cc profiler heads, and 5 cc flat top speed pro pistons, stock l98 piston height.
My cam is a 268xfi, and it will be installed for normal timing.
Did I miss calculate? Will my quench be sufficient?
Additionally, anyone ran this and know ptv clearance to be ok? I know to check, but I'd like experienced input. The lift is .565/.575.
Old Aug 29, 2014 | 09:27 AM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: quench, compression ratio pcv clearance, and me.
The .040" quench is good.I get 10.25:1 with the info you supplied. 4" bore,.040" quench,5cc piston,3.48 stroke.
Old Aug 29, 2014 | 04:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The PCV valve and its breather inside the valve cover should sit in between the intake rockers of adjacent cylinders. Should not be an issue. Unless the rocker arms you're using are exceptionally wide.
Old Aug 29, 2014 | 05:29 PM
jokerZ71's Avatar
Engine: 5.7 Vortec
Axle/Gears: 3:42
I think he was asking about piston to valve clearance.His title does say PCV,but,then he says PTV in his post.
Old Aug 29, 2014 | 06:10 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Now that makes more sense.
Old Aug 29, 2014 | 06:22 PM
Damon's Avatar
You miscalculated the compression ratio somehow. That's a bit over 10:1, given the specs you provided. Quench height will be perfect (.040 gasket + 0 deck on the pistons = .040" quench distance. Very simple, and right where you want it.)
Valve-to-piston clearance is something you'll need to check upon mock-up to confirm. But given most performance aftermarket pistons have fairly generous valve reliefs, I think you'll be just fine with that cam.
Old Aug 29, 2014 | 06:56 PM
truckerz's Avatar
Car: 1989 Formula
Thanks. I have read about very, very similar builds for a fun Street car, and this setup seemed perfect. I'll re check my math and figure out where that extra point or so came from. I haven't heard of anyone running into ptv problems with the relieved flattops yet. Every part was name brand and expensive, even some of the second hand stuff.
So thanks for the input!
Old Aug 29, 2014 | 06:58 PM
truckerz's Avatar
Car: 1989 Formula
Yep. I'm on a mobile, and the stupid thing keeps putting pcv, or pvc when I put in PTV........I just didn't catch it.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
tyeo098
Nov 30, 2015 06:27 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
