oil leak cant find it
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I have. a 383 just got running it only seems to leal oil when u Drive it, it run down the back of the block on both sides ive sealed the oil sending unit mĂșltiple times and still leaks , can it leal anywhere else?
Posted from Thirdgen.org App for Android
Car: 86 IROC-Z
Axle/Gears: 3:42
I doubt it because it s wet Where the intake and the block meet on the back of the block all I can think is the oil sending unit But ive re sealed it like 3 times
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: oil leak cant find it
clean it off. and check whether or not the intake rubber seal is leaking .its the one at the back of the block
Car: 89 IrocZ
Engine: L98-ish
So when you put it together, did you use the cork or rubber seals?
Many years ago I learned to toss them and just run a 3/16th bead of sealant instead.
Works good, last a long time
Navy8125
Aug 21, 2015 09:32 AM
