406 efi build
406 efi build
Alright i have a 88 irocz 305tpi iam in the process of building a 400sbc 30 over.. so far i have bought the weiand stealth ram kit, afr 195 heads 65cc, xfi 280 retro fir hydraulic roller cam 280 288 duration @50: 230 236 valve lift 576..eagle rotating assembly all forged mahle pistons, h beam rods 6 inch and a forged crank... what type of horse power could i expect and could i possibly throw a turbo on this set up
Re: 406 efi build
Re: 406 efi build
I think you'd do better with 30 or 32...
Smaller injectors with higher fuel pressure, tend to do better than too-large ones with low FP.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: 406 efi build
Mine is a close comparison
I have a stockblock 400 with 4.125 piston and 3.75 crank and 5.565 rod.
I have the 280xfi (flat hyd version though)
9.2 compression, 1 7/8 headers, LT1 intake (miniram),
3550 lbs with me in the car, 3.75 gears, 3500 stall
12.1@111 na
12.1@111 na
Car: '91 GTA
Engine: 421sbc
Re: 406 efi build
According to this calculator
http://www.wallaceracing.com/hpcalculatorquarter.php
Your HP computed from your vehicle ET is 355.57 rear wheel HP and 395.08 flywheel HP.
Your HP computed from your vehicle MPH is 350.87 rear wheel HP and 389.86 flywheel HP.
I think I was a 1.64 60ft
Remember, hp means nothing if you don't have a proper combo (gears, stall, traction)
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 406 efi build
Thats a 400-420 whp build if it has 11:1 comp and ported intake. And good ring seal lol. But 380-400 isnt out of the question
If it was under or around 10:1 you could turbo it. Almost identical to what i used to have in my first turbo build
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 406 efi build
On AFR's site they have listed a 383 with that cam and the 195's at 10:1 compression ratio and performer RPM making just over 500 at the flywheel. So figure a 400 making an easy 25 horepower more. If you haven't bought the heads yet and are building a 400 pay the extra and go with the 2.08 valves or move into their 210s and get a 2.1 valve.
Car: 1991 Z28 Vert
Re: 406 efi build
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 406 efi build
406 Stealth ram, E-tec 200 heads, 10.0 compression, 6" rods, HR 280/280 226/226 .554 lift 112 LCA cam, 1-3/4 headers
