Fuse next to battery keeps blowing.
Old Oct 15, 2014 | 04:58 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
87 gta trans am
Tpi 350
There's a fuse next to the battery I think it's for the fuel pump?
When the engine get warmed up and I drive it the car will shut off and all the gauges will stop working like the power is cut off on the entire car. I look at the fuse and it blown. Does anyone know what this fuse does? Anyone have a schematic for that wire so I can trace it.
Old Oct 15, 2014 | 05:16 PM
Engine: 5.7 350 TPI
Re: Fuse next to battery keeps blowing.
Does anyone have a pic of how there's is hooked up? Picks would help a lot!!
Thanks in advance
Old Oct 15, 2014 | 05:56 PM
OrangeBird's Avatar
Car: 1989 Firebird
duplicate message
Old Oct 15, 2014 | 05:59 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thanks in advance
I don't seem to be able to get a link to work , but , if you search wwwaustinthirdgen.org that site has all the wiring diagrams for our cars ...
Old Oct 15, 2014 | 06:04 PM
Engine: 5.7 350 TPI
Thank so much for the quick reply.
Also when the car does shut off I hear a loud squeaking noise from one of the relays on the firewall on the driver side
Any idea what that can be. Should I replace the relays?
Old Oct 15, 2014 | 06:36 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
That fuse is the Fuel pump / ECM battery fuse. If the relay is squeaking could be the reason the fuse is blowing. I would replace the relay and go from there.
Old Oct 16, 2014 | 10:21 AM
Engine: 5.7 350 TPI
Wouldn't a bad relay make the fuse blow right away or make the car not even start? Does autozone oar pepboys sell these relays?
Old Oct 16, 2014 | 01:20 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
stay VERY far away fro both auto zone AND pep boys for your parts. go to NAPA or oreilleys. I have the GM part numbers for the relays ,should you want them. the fuse by the battery in a weather proof connecter is for the ECM main power . if it blows .you have a short somewhere.
Old Oct 16, 2014 | 04:17 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
That fuse provides constant battery power to the fuel pump relay, fuel pump oil pressure switch, MAF relay, MAF burnoff relay, and ECM. Veaceonee said that the relay making the squeaking noise is a likely culprit and he's right. I would at least start my checking there. If it's not the relay itself, it is the circuit that that relay controls. My suspicion, next to relay being at fault would be the fuel pump or the fuel pump oil pressure switch. With the age of the car, it could also be wiring that is touching ground somewhere. Check all of the wiring from the noisy relay for short to ground. NAPA has the relays.
The reason that the fuse doesn't blow immediately when you start the car is probably because the draw is just at the limit of the fuse's capacity. The high draw heats the fuse until it finally breaks.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
lanceflame44
Sep 25, 2015 12:28 PM
