How to replace A/C evaporator casing?
Old Nov 2, 2014 | 03:08 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
What do I need to remove in order to replace my A/C evaporator casing? (firewall passenger side). Here is a picture: http://www.ebay.com/itm/82-92-Camaro-Firebird-AC-A-C-Evaporator-Case-/361044132314?pt=Motors_Car_Truck_Parts_Accessories&hash=item540fe841da&vxp=mtr
I found one at a pull-it-yourself junkyard. I was able to get the top part of the casing off, but I couldn't figure out how to get the lower half off.
I need the lower part because that's the part I damaged while installing my headers.
Old Nov 3, 2014 | 03:53 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: How to replace A/C evaporator casing?
take the fender off for working room. and you can do the job.it aint easy with the engine in the car in any case. and as for what to do when you get it finished.if you don't make a heat shield for it. your headers will melt it.
Old Nov 3, 2014 | 08:50 AM
Joe Tag's Avatar
I'm not sure how that will help a bit. ???
Been a while since I've done mine, but I am certain there is at least one bolt from the inside of the cab (possibly two?) that you are not seeing. You will need to pull the hush panel and look for them.
Old Nov 3, 2014 | 11:27 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I just replaced mine couple months back, Removing the fender will get you nowhere. You need a 1/4" drive ratchet-extension and universal joint to get to the lower screws around the fender well area on the bottom half, There's three screws inside you'll have to pull the carpet and sound deadner back to get to......
Old Nov 3, 2014 | 05:08 PM
Comes off ALOT eeeeezier all in one chunk, evap and all, than taking it apart first and pulling it one half at a time.
LOOK at the pic you posted. You can see where all the hardware is, plain as day. There's about 3 bolts across the bottom, that you get to under the front edge of the carpet.
Old Nov 3, 2014 | 09:30 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Wow I can't believe I didn't think about bolts from the inside! That's probably all I was missing to take it out, since I got it fairly loose. Can't wait to go back to the junkyard and try again.
Also do I need to remove the A/C accumulator? I wasn't able to remove the nut on the pipe that goes to the evaporator, but I only had a crescent wrench with me.
Old Nov 4, 2014 | 06:08 AM
Just undo its little bracket strap thing and leave it attached to the evaporator coil.
If you step back and study what you're doing carefully, you'll notice that you can remove the ENTIRE A/C assy - compressor, condenser, evaporator with housing and blower motor, lines, and accumulator - as a single unit without disassembly. In fact I'm pretty sure that's how it went in; shipped to the factory already assembled and charged with the right amount of Freon, and they just dropped it in as the car went down the line.
Old Nov 4, 2014 | 02:06 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Yeah I see what you're saying. I've removed the compressor while leaving it attached, if that makes sense.
I probably should have done that with the junkyard A/C system. It looked in much better condition than mine. How would you get the condensor with it too though? You would have to take out the radiator right?
Old Nov 4, 2014 | 03:58 PM
Car: 86 IROC
Engine: 5.0 TPI
I would flush the evaporator before I put it all back in. and its smart to just buy a new condenser. to replace it you don't have to remove the rad. just take off the top brace and tilt it back and it just slides into place
Old Nov 4, 2014 | 06:23 PM
Zackly: w/o the rad, the cond just lifts right out.
Old Nov 8, 2014 | 08:06 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Where exactly are those bolts on the inside? I pulled the carpet, peeled away the layer of dumdum/rubber mat, took off the knee bolster cover, took off the dashboard, and still couldn't get it out. I loosened almost every bolt and screw and fastener I could see. I took the dash halfway out of the car too.
Frozer!!!
Jan 19, 2024 04:55 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
BikeFarm
Aug 11, 2015 11:35 PM
