cam lsa
Old Nov 28, 2014 | 04:15 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Axle/Gears: 3.55 12 bolt
cam lsa
I have a 69 chevelle with stock maf tpi stealth ram intake a 700r4 with 3.55. My old 350 blew up and i am looking to replace it with a blueprint engine BP35512CT1 the cam is a mild flat tappet but has a 110 lsa . It may not be the best choice but will the computer work with it.
Old Nov 28, 2014 | 04:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: cam lsa
Its not LSA that makes or breaks computer compatibility, it is duration and overlap. The stock 305 peanut cams are 109* LSA.
Old Nov 28, 2014 | 04:34 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Re: cam lsa
Cam Type: Flat Tappet
.480 Intake .486 Exhaust
229 Intake / 230 Exhaust duration*
@ .050 these are the cam specs
Old Nov 28, 2014 | 04:40 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
That's not a mild cam ... u better have a good tuner or get the ebl n learn to tune , bigger injectors , higher fuel pressure , more initial timing , ... the whole tune will need to b redone spark advance Ve tables etc.
Old Nov 28, 2014 | 04:43 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: cam lsa
Except he has a MAF TPI setup and would have to swap to speed density to run the EBL.
Old Nov 28, 2014 | 04:55 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Re: cam lsa
Injectors and fuel pressure are not a problem my pump will put up 70 lb and i have an adj regulator
Old Nov 28, 2014 | 05:04 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Re: cam lsa
I run 43.5 psi now with 24# inj
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
