Which Oil Pan to use? Hooker
Old Dec 6, 2014 | 12:45 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
I have Hooker Headers Competition Shorties: 2460HKR with the offroad ypipe: 16767HKR. I'm curious to hear of anything causing issues with aftermarket pans, its pretty close to begin with at my oil pan now. I want a little upgrade as the chrome pan isn't cutting it.
Old Jan 4, 2015 | 10:12 PM
Engine: 357
Re: Which Oil Pan to use? Hooker
Bump...
After some research. I think i can use this oil pan with the hookers shorties:
http://www.jegs.com/i/Canton-Racing-...5-244/10002/-1
After further research, i think this pan may work aswell:
http://www.jegs.com/i/Canton+Racing+...5-010/10002/-1
Anyone run into this?
Old Jan 5, 2015 | 12:59 AM
Night rider327's Avatar
Car: 1988 Camaro
I used the summit 7qt kicked out sump pan http://static.summitracing.com/globa.../sum-g3502.jpg
(2 pc rear main seal engines) with the old hooker shorties and the hedman long tubes.
The summit pan is a Milodon 30900 blem/second/copy.
Here's 3 pictues of mine. 1st two are with the hooker shorties, and last one is hedman long tubes
Attached Thumbnails Which Oil Pan to use? Hooker-picture-238.jpg   Which Oil Pan to use? Hooker-picture-239.jpg   Which Oil Pan to use? Hooker-dscf3572.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
