Edelbrock Hi-flow TPI intake
Old Dec 30, 2014 | 10:50 AM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
About to make a large purchase and want to make sure all this will be compatible with my stock 350 Iroc-Z motor. Also what else should I buy? On the front of my stock intake base plate there is a sensor that is locktited in, what sensor is this? Does it matter that the Holley throttle body is for EFI? Advice or recommendations?
Link for each part.
http://www.summitracing.com/parts/edl-3891
http://www.summitracing.com/parts/fel-ms930351
http://www.summitracing.com/parts/hly-112-506
Old Dec 30, 2014 | 11:16 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Edelbrock Hi-flow TPI intake
One brass fitting on the front of your intake is the Coolant Temp Switch. The other one that has a injector type connector is the Cold Start Switch for the 9th injector (If you have a setup with the cold start injector 88 and below)
Are you getting new injectors?
new AFPR?
Old Dec 30, 2014 | 11:18 AM
nakota2k's Avatar
new AFPR?
The injectors are less than 6 months old so probably not. Should I get an AFPR? What is the advantage?
Old Dec 30, 2014 | 11:20 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
One would be for future upgrades to dial the pressure in, and you're already there, so why not put it in.
Old Dec 30, 2014 | 11:24 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Also, look into the intake/runner bolt kits and get rid of the torx type if you still have those.
Old Dec 30, 2014 | 11:59 AM
nakota2k's Avatar
Can you link me to an AFPR? I can't seem to find one that includes the diaphragm.
Old Dec 30, 2014 | 12:12 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Southbay Fuel Injectors has them for $49.99
85-92 GM TPI ADJUSTABLE FUEL PRESSURE REGULATOR
http://cdn2.bigcommerce.com/server22....68.68.JPG?c=2
Old Dec 30, 2014 | 12:40 PM
nakota2k's Avatar
Thanks, I wish Holley made one for the 5.7..
Old Dec 30, 2014 | 09:50 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Put a Holley decal on it, Done.
Old Dec 30, 2014 | 10:10 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You don't use locktite on the sensors, use pipe sealant.
Don't need the T-body if you have a stockish motor.
And holy ^&*( when did those parts cost more than kids do?
Old Jan 1, 2015 | 03:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Back in 1989 when I purchased a Hi-Flow base to replace the warped OE base, I don't think I paid more than $300 for it.
The SLP runners that I ordered with the base were around $400 so maybe the price the OP posted for the manifold and runner kit isn't too outrageous.
Old Jan 1, 2015 | 08:49 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
The regulator is the same for the 5.0 and 5.7. Personally, I'll never buy another one with the adjuster nut and bolt on top again. I got one from southbay, and the adjuster hit the plenum so it had to be ground down. Trying to adjust the pressure was a bitch and a half with everything put together too.
1992rs/ss
Jan 31, 2025 05:10 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
