Throttle Body Help
Old Jan 27, 2015 | 03:47 PM
Madmax05's Avatar
Car: 87 Iroc Z28
Axle/Gears: Borg Warner 9 Bolt
Throttle Body Help
Hey all,
New to the board, just got back into the third gen game after many years. I have a stupid question I was looking at my motor today and noticed the stock throttle body on the passenger side has three hoses connected to it, I know the bottom hose is the coolant line and the other two are vacuum lines. But every aftermarket throttle body does not have the middle or second line coming out of it. On my motor it wraps under the throttle body and comes out the driver side and runs to the canister right by the driver side headlight. Can that line be bypassed or am I going to have to deal with the annoying service engine light. I am changing the stock throttle body to a professional products 52mm part # 69704. I assume I have the right part because everywhere I checked this is the part number for my car. I have searched the various forums without any luck. Any help would be greatly appreciated.
Old Jan 27, 2015 | 03:58 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Throttle Body Help
Some newer aftermarket throttle bodies have a coolant bypass, meaning the two ports are vacuum only with no coolant passage. It helps keep the air-charge cooler as it enters the plenum.
Old Jan 27, 2015 | 07:19 PM
Madmax05's Avatar
Car: 87 Iroc Z28
Hey Ozz,
Thanks for the reply. The problem I'm having is with the second line or the middle one. Aftermarket throttle body doesn't have it. Would like to know what I can do with the vacuum line that goes under the throttle body and out the driver side to the vacuum canister near the headlight
Old Jan 27, 2015 | 08:08 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Originally Posted by Madmax05
Hey Ozz,
I would "T" it into another line for now since you need the vacuum canister.
Old Jan 27, 2015 | 11:46 PM
Madmax05's Avatar
Car: 87 Iroc Z28
Is that safe to do
Old Jan 27, 2015 | 11:48 PM
Ozz1967's Avatar
Car: 1984 Trans Am
As long as its to a vacuum port yes. Or you can plug it. Just dont leave it because that will cause a massive vacuum leak
Old Jan 28, 2015 | 12:11 AM
Madmax05's Avatar
Car: 87 Iroc Z28
I'll give it a shot and see what happens, thanks Ozz much appreciated
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
