car stalls out of nowhere
Old Jan 27, 2015 | 11:09 PM
jack_jack-jr's Avatar
i have had this car for about a year now. it is a 92 firebird V6 3.1 and it has no performance parts. i was driving in town when i heard this loud clater on the bottom of my car after i heard where it sounded like something fell out of my engine. then not to long later my car stalls out of nowhere no studer just died on a interstate. i ended up getting home and i fixed the sound it was from water pump. then my car kept stalling still. i can drive but anytime im at a slowing down position i have to put my car in neutral and rev the car alot. then put it in drive and go. i have tried replacing the fan motor because my car got hot, and i have replaced the fuel filter and i replaced the spark plugs and wires about a month ago. i also replaced the coil pack. i have tried everything i can think of to try and get my car to stop stalling but nothing has worked at all. does anyone here have any idea what it could be?
Last edited by jack_jack-jr; Jan 27, 2015 at 11:14 PM. Reason: missed important stuff
Old Jan 28, 2015 | 12:20 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: car stalls out of nowhere
Did you replace the water pump? Can you tell whether your themostat is working properly? Did it overheat on the interstate when it died?
Old Jan 28, 2015 | 02:51 AM
Yes I replaced the water pump. I replaced the thermostat about 3 or 4 months ago. I was told that it showed on the gauge 1 time it went close to overheating but I was sitting still when it happened. But it hasn't overheated anymore. I was told that it sounds like it could be the crank position sensor
Old Jan 29, 2015 | 07:12 AM
OrangeBird's Avatar
Car: 1989 Firebird
Whoever told you this , is hereby DISQUALIFIED from giving you any more advice about your car . period .
Why , you ask ?
Because your car DOES NOT have a "Crank position sensor" !
Old Jan 29, 2015 | 01:51 PM
I was told by autozone. I just had my idle air control valve cleaned worked good for a few then stalled again after I thought it worked
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
