Chain rattling noise continued
Car: 86 Trans Am
Engine: 305 LB9
Hey guys,
Thought I had solved my issue. What happens in when I'm driving I have the windows down because naturally I don't have ac. When I'm driving I hear a loud chain rattling noise that comes and goes. I hear it most when I'm near buildings where the sound can bounce off.
Haven't been able to pin point if its front or rear, however the exact sound rears its ugly head if I close the hatch hard (pull down motor died).
Any ideas on this? I'm getting under it today to check heat shields. Also I believe the cat has been gutted by prev owner as well.
Car: 86 Trans Am
Engine: 305 LB9
Car: 1988 Camaro
Re: Chain rattling noise continued
Does it sound like shaking rocks in a tin can? Are you under load or going up hill when it does it?
If so it could be detonation (spark knock)
Car: 86 Trans Am
Engine: 305 LB9
Pretty simple, crawl under the car, have someone bounce the rear end and follow the sound. End link and shock washers will sound like chains rattling as Sofa said.
Engine: 4++,350 & 305 CIs
Swaybar parts loose or broken. Or maybe the spare tire parts rattling around?
Car: 86 Trans Am
Engine: 305 LB9
Here's an update,
Checked the end links, and all were tight and looked almost new. I believe the entire suspension was replaced about 15k ago.
I can nearly pin point the sound to the rear always. Never when I close doors just the hatch. And cruising around sounds like I'm dragging chains only sometimes.
I got under it and had a friend close the hatch and it didn't make the noise of course. Tightened all the heat shields and banged the exhaust around to no avail. I will see what difference tightening those shields up did when I get off duty.
Car: 86 Trans Am
Engine: 305 LB9
Forgetful me forgot about the topic today. I always find interesting threads to read
Anyway I have banged around. No noise. When driving I still here it. However it is different now it seems
For one, the second time I lost a center cap, I glued those ****ers on. Pretty sure they are the rattle.
I have isolated it to the read end however. When going over speed bumps, the front is silent, the back sounds like the center caps or loose. That kid of plastic rattle nois . And after I speed up you hear the chain noise. Possible rear end issue?
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
check the shock mount bolts under the rear seat carpet my 95 did it after a shock change.drove me crazy. the washer rattled under the bolt and shock rubber
Car: 86 Trans Am
Engine: 305 LB9
Those all look in tact. Which is making me a little worried about what it could be. I'm going to dig around some more while it is still nice out
Car: 86 Trans Am
Engine: 305 LB9
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Do you have the WS6 Rear Disk Brakes?If so check your Rear Calipers.They could be frozen and just hanging on for the ride,I had that problem and they rattled like crazy.Didn't sound like a chain though.
Car: 86 Trans Am
Engine: 305 LB9
Last night I found a almost broken muffler hanger that I'm going to replace today. Frustrating issue trying to find the cause.
Another thing to check is the top of the rear shocks.
Pop the rear seat out and peel th ecarpet back.
skinny z
Oct 5, 2015 06:23 PM
sjorgens
Oct 1, 2015 07:54 PM
