Worst Gas Mileage
Car: 1987 IROCZ28 Camaro
Worst Gas Mileage
I have a 1987 5.0L 305 V8 IROC-Z28 with 2.73 gears. The car has 116k on the engine. Recently I've been driving it around and I've been averaging 4mpg. I don't beat on the car, I drive the speed limit and have ran fuel injector cleaner and I run full synthetic fluids.
Anyone have any ideas on how to improve this or diagnose possible problems? I'm not running any codes. I plan on replacing the fuel filter, the plugs/wires/cap/rotor, and do full fluid flushes as well as sea foam. Any other options?
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
Re: Worst Gas Mileage
I'd do a full tune up, and also CHECK FOR VACUUM LEAKS!
The number one cause for bad mpg is vacuum leaks.
I get 28mpg highway and 18mpg in town in my 5.0 tbi.
Car: 88GTA
Engine: 5.7TPI
BTW....Don't feel bad...... Tractor Trailers loaded @ 80,000lbs get 8mpg....oh wait....feel bad
Just ribbin ya
Car: 89 Firebird
Engine: 355 TBI
Damn does it have a hole in the gas tank...Never heard of that kinda mileage!
Thanks for the suggestions, I've had some other plans for it along the way. I overlooked the vacuum leak at the intake manifold. Causes a high idle when in park but drops down when in gear but I'm sure that has a bit to do with it. I already have the gaskets so we'll see if anything changes after they are installed.
Car: 88GTA
Engine: 5.7TPI
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
