Very low exhaust temperature - 200F
Old Mar 15, 2015 | 11:11 AM
southbaysd's Avatar
Car: 1990 Firebird Formula
Engine: 5.0 TPI
Hi TGO friends,
I have a 1990 Pontiac Firebird Formula with the 305 engine, TPI, and I recently had new head gaskets installed, installed new pushrods, rockers, all intake gaskets, cleaned all carbon from intake, pretty much replaced all worn parts, etc. all installed according to service manual, followed all the torque specs, etc.
Also have new exhaust and cat. converters.
The passenger side exhaust is running "cold", around 200F, while the drivers side exhaust is around 500-650F, so there is a difference of 400F degrees between exhaust manifolds measured with an infrared thermometer
I understand the 500-650F temp is normal, while the 200F does not seem normal to me
- Timing was set to 6 BTC
- Can't hear any misfire
- Knock count stays at 0
- No error codes
- Tested resistance of injectors, all have similar resistance, 14.8 ohms
- Cat. converters also differ in around 100F from each other
I ran out of ideas.
Any help will be appreciated
Old Mar 15, 2015 | 01:10 PM
ex-x-fire's Avatar
Re: Very low exhaust temperature - 200F
Does the engine run smooth?
Old Mar 15, 2015 | 01:23 PM
southbaysd's Avatar
Engine: 5.0 TPI
Yes, it looks smooth to me and several people that have looked at it.
I did a compression test BEFORE taking the heads out and all the cylinders had around 165-170 psi.
Old Mar 15, 2015 | 01:57 PM
southbaysd's Avatar
Engine: 5.0 TPI
I have recorded a video to show this problem
Old Mar 15, 2015 | 04:01 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Your bank 2 injectors aren't firing. Check 12v power supply to bank 2 and ECM ground pulse to bank 2.
Old Mar 15, 2015 | 05:00 PM
Cosmik Debris's Avatar
Wouldn't that make the engine run lean and be noticeable in quite a few ways?
Old Mar 15, 2015 | 06:37 PM
Damon's Avatar
No way. Nothing with half the cylinders not firing runs that smooth. Get a spray bottle and shoot a little water on it. It should sizzle off almost immediately. If it just sits there and slowly boils away, yeah, it's definitely cold.
Agreed with others, one bank of injectors not firing would be the only thing I could think of that could cause a whole bank not to be firing. I mean unless you got all 4 plug wires on the wrong plugs on that side. Still, it would be barely running if either was the case.
Old Mar 15, 2015 | 06:51 PM
ex-x-fire's Avatar
Maybe the air injection is only working on one side.
Old Mar 15, 2015 | 07:17 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Only one O2 sensor, and it's in bank 1.
Old Mar 15, 2015 | 07:22 PM
southbaysd's Avatar
Engine: 5.0 TPI
Thanks everyone for your comments.
I just did the "screwdriver" test, but instead I used a stethoscope and in fact, none of the injectors of bank 2 are clicking.
Oh crap, and I drove like this for 5 miles this weekend.
I checked the fuses for INJ #1 and INJ #2 and both are good, and both show 12V passing through.
Will need to continue troubleshooting, if anybody has an idea, it will be greatly appreciated as always. Good thing is I have the service manual
Old Mar 15, 2015 | 07:26 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If both fuses are good, check for 12V right at the injector connector. If yes, then either the trigger wire from the ECM is open, or the driver in the ECM is shot.
Old Mar 15, 2015 | 08:21 PM
southbaysd's Avatar
Engine: 5.0 TPI
Hi and thanks for your help
Both wires in the injector connector are at 12V, so it seems to be a problem with the ground pulse from the ECM, from what you are saying? Either the wire or the ECM itself? Thanks
Old Mar 16, 2015 | 05:13 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
On injector connector, pink/black wire should have 12v whenever the key in on. The green wire should have nothing with key on/engine off, but ECM will pulse ground here with engine running to fire injector.
File Type: pdf
Old Mar 16, 2015 | 09:22 PM
southbaysd's Avatar
Engine: 5.0 TPI
Thank you, I followed the diagnostics in the service manual and it seems circuit 468 (Dark Green cable) is open.
Will keep you guys posted
Old Mar 17, 2015 | 07:45 PM
southbaysd's Avatar
Engine: 5.0 TPI
This has been fixed. Thanks everyone for your guidance and help!
The injectors of the passenger side are firing for the first time after this big repair
Old Mar 18, 2015 | 10:32 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Don't be so sure about that.....I accidentally ran my Express van on 4 cylinders one day after messing with a valve cover I never put the plug wires back on the distributor. Took me some time to figure out why it idled/ran smoothly but fell on its face under load. It was still dead smooth under load, just no power.
Old Mar 18, 2015 | 10:39 AM
southbaysd's Avatar
Engine: 5.0 TPI
I am with Damon, and that is what confused me, because I never thought an engine working with half the cylinders could run so smooth, so I never even considered that option. I thought the same, there is no way this engine is running on 4 cylinders only.
However, after eseibel67 brought it up, I gave it a try and he was absolutely correct.
I think this is a lesson learned that we need to have an open mind when troubleshooting engine issues
Old Mar 18, 2015 | 09:28 PM
Damon's Avatar
Thanks. I appreciate you sticking up for me even though I was dead wrong.
Reddeath210
Oct 6, 2015 08:20 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
Logan Bryant
Aug 27, 2015 11:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
