Air cleaner clearance for stock hood
Old Mar 21, 2015 | 08:05 AM
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
I am sure this has been asked 100 times but I am planning on replacing my butchered factory hood with its poorly added cowl that weighs a ton to a factory style hood that uses the rear hinges and hood pins in the front that weights 20 LBS. I have a Performer EPS intake with a Holley vac carb and am wondering who is using a good drop base air cleaner that clears and what height of element you are using. Going to be probably getting to hood in a few months but will probably be getting a new air cleaner soon and might as well get one that I don't have to replace later.
Old Mar 21, 2015 | 08:54 AM
Car: 86 Z28 T-Top
Engine: Vortec 350
Re: Air cleaner clearance for stock hood
Never mind just going to go with a 2.5" hood as its the same weight.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
bryan623
Aug 10, 2015 11:33 AM
