small block 350 heads issue for 89 camaro
Old Apr 26, 2015 | 05:19 PM
austindooley89's Avatar
Car: 1989 RS Camaro
Engine: 350 TBI
Hello all, I bought a set of small block 350 heads from a friend of mine because I was replacing my old ones. After I was about ready to install them I realized that the heads weren't as tall and they were not center bolted like my original heads. I am trying to figure out if these heads will still work and if not then I will need to buy new ones. The engine is a small block chevy 350. I believe it is in the range of 87-95 and it is in my 89 rs camaro. I just bought a edelbrock tbi intake the other day and all I need is to get the heads situation figured out before I can put it back together. Any input and thoughts would be greatly appreciated. Thank you!
Old Apr 26, 2015 | 05:50 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
Re: small block 350 heads issue for 89 camaro
no clue what you have.... Kinda need a picture to see what the deal is.
Old Apr 26, 2015 | 06:11 PM
Car: 1989 RS Camaro
Engine: 350 TBI
Alright I will go and take some pictures and post them thank you!
Old Apr 26, 2015 | 06:36 PM
Car: 1989 RS Camaro
Engine: 350 TBI
Hope these help. The taller one is what I took out of my camaro, the shorter one is the one I bought from my friendsmall block 350 heads issue for 89 camaro-unknown-1.jpeg
Old Apr 26, 2015 | 07:08 PM
estesformula87's Avatar
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
there should be a number on the top under where the valve cover goes this is the casting number what is it
Old Apr 26, 2015 | 07:23 PM
Car: 1989 RS Camaro
Engine: 350 TBI
on the set that came from my camaro - 14102193
on the set that I bought - 14014416
Old Apr 26, 2015 | 07:40 PM
Car: 1989 RS Camaro
Engine: 350 TBI
do the numbers need to match in order to work?
Old Apr 26, 2015 | 08:29 PM
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
the last three numbers are what matter the 416 are 305 heads that is why they are smaller they are around 58cc chambers
Old Apr 26, 2015 | 08:42 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Looks like you have 4 boat anchors
Old Apr 26, 2015 | 09:44 PM
Car: 1989 RS Camaro
Engine: 350 TBI
well they are smaller than my original 305 heads from before I swapped to the 350... I just thought maybe they were older heads or something... looks like i might have six boat anchors...
Old Apr 26, 2015 | 09:52 PM
Car: 1989 RS Camaro
Engine: 350 TBI
What about these numbers? 14102187? These numbers came from the very original heads that were on my 305 before I swapped to a 350. They don't have the 416 you were talking about.
Old Apr 26, 2015 | 10:22 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
187 heads are from a TBI 305 I'm pretty sure.
Old Apr 27, 2015 | 12:21 AM
Night rider327's Avatar
Car: 1988 Camaro
The small block chevy is very interchangeable. You can out 1955 265 cid heads on your engine and it will work.
Yes the heads you bought will bolt on and work if you match rest of parts right.
The big diff here is center bolt valve covers vs perimeter bolt valve covers.
Rocker arm style. The chevy bolt heads also got self aligning rocker arms, where the perimeter bolt heads got non self aligning and the two types of rockers can not easily be swapped. Most use the type of rockers that head was made to use.
Intake bolt pattern. The perimeter bolt heads had all 12 intake bolt holes at an angle.
The center bolt heads had the 4 center bolts of intake at a more straight down angle.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
armybyrd
Dec 5, 2015 09:22 AM
camaro71633
Sep 1, 2015 10:24 AM
