Removing OEM oil pan
Old May 11, 2015 | 01:31 PM
scorpiusx's Avatar
Car: 1985 IROC Z
Engine: 305TPI (LB9)
Transmission: TCI 700R4
Does anyone know if the OEM oil pan can be removed on an '85 IROC Z 305TPI without raising the motor or disconnecting the motor mounts?? Thanks...Joe
Old May 11, 2015 | 01:42 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Removing OEM oil pan
Hey Joe, nice font.
You will need to raise it a few inches and put blocks under the mounts.
You might want to take your dizzy cap off to.
Old May 12, 2015 | 11:01 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I had to lift the engine slightly out of the engine bay to change the pan
https://www.thirdgen.org/forums/tech...nge-while.html
Old May 13, 2015 | 12:51 PM
scorpiusx's Avatar
Car: 1985 IROC Z
You've got to love those damn GM engineers. I'd like to kidnap them and make them remove and replace my oil pan. I've already done this on my old '78 Merc cougar.
Old May 13, 2015 | 12:54 PM
scorpiusx's Avatar
Car: 1985 IROC Z
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
