Can I swap an 1989 L89-350 into a 1987 Iroc l89-350
Old Jul 13, 2015 | 05:38 PM
D-87iroc's Avatar
I cracked a head on my 1987 Iroc L89 350. I found a L89 350 out of a 1989 can I swap them out? It is a complete engine. Thanks guys!!
Old Jul 14, 2015 | 05:03 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Yes, a 89 L98 will direct replace a 87 L98 with no further changes.
Old Jul 14, 2015 | 01:16 PM
D-87iroc's Avatar
Re: Can I swap an 1989 L89-350 into a 1987 Iroc l89-350
I got the engine today but I don't think it's out of an Iroc wonder if it's worth putting in. Heads read 14102193 and the block reads 024388. It's complete drop in ready.
Old Jul 14, 2015 | 01:32 PM
No, that's not an L98. Not with those heads. Those are swirl ports, a truck head. Generally considered boat anchors though some people work with them. If you decide to use them is up to you but I'd expect a hp loss. Maybe no torque loss in the lower rpm due to design.
It also may or may not have a roller cam in it. I would NOT use it without the cam your L98 has or better.
Old Jul 14, 2015 | 02:22 PM
D-87iroc's Avatar
Bummed, maybe just throw a beefed up carbureted engine in?
Old Jul 14, 2015 | 02:28 PM
Nah, don't do that. Find a good motor or rebuild the original. Sell the one you got. Find another and check casting numbers first.
Old Jul 14, 2015 | 03:02 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Well now wait a min, How bad is the cracked head? A shop look at it yet?
Old Jul 19, 2015 | 02:16 PM
Or you may want to check into this....https://www.thirdgen.org/forums/engi...tpi-motor.html
Out-Cast
Dec 31, 2015 04:40 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
