88 305 tbi will not stay running
So everything was fine and now it will not stay running for more than a minute , whether in gear or not. I can hold throttle open to steady 2000 rpm and it will just drop out. I have replaced iat sensor , cap and rotor, coil , fuel pump relay and harness. Plenty of fuel appears to be dumping in tbi , it will just stop about 45 seconds after running.
What is next?
What is next?
Transmission: T-5, TH350, T-5
Re: 88 305 tbi will not stay running
When it fails again, check if you lost fuel or spark. My guess it will be spark, then it nery well could be your ign. module.
I think your on to something. I pulled the cap again and pulled the module it it was pretty corroded. The two wires- green and white that connect - plastic plug disintegrated . I picked up a new module , but need to figure out a repair on the plug.
Thank you for the advice
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
how long did u let it run after the change?....you prolly have to much fuel in the intake..(flooded sorta speak) give it time to burn it out..for bit..
check your plug wires..make sure you got the correct firing order..1 plug off gonna run like sheet!!!!!
Fuel actually misting out the top of the tbi
No neither of those things "is the computer". More likely, a bad connection somewhere. If your car has the in-line fuse thing off the battery (can't recall offhand which ones are wired that way) then that's where I'd start looking.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
http://austinthirdgen.org/mkportal/m..._continued.gif
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
