1990 Corvette L98 into 1991 L98 Z28
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
I have an opportunity to buy a L98 motor with 35K. I know about drilling the extra hole in the head for the bracket, I would have to use the L98 manifold
for the EGR passage and modify my passenger header and use my fuel rail since the lines are on the driver's side. My question is since they are both SD and both 5.7, can I use my computer and small cap distributor? Also, do I hook up the EGR the same way as the factory Camaro L98?
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: 1990 Corvette L98 into 1991 L98 Z28
Less than 12 hours isn't always enough time for an educated person to come across your thread.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Just use your existing wiring, ECM and intake. The small cap you can reuse too. You can delete the EGR out of the prom and not worry about hooking it up.
Car: 1992 Formula 350
Engine: 5.7 L98
Funny you should post this. I posted a similar question in the past. I have a 44,000 mile L98 from a 1991 Corvette I'm putting in my 1992 Formula 350. I am going to use the upper and lower intake as well as the distributor from my Form. I guess I will just see what else I need as it is being installed. Still throwing ideas around about a cam, HSR, and maybe a swap to a T56. Here's how I sit now
Engine: 4++,350 & 305 CIs
Tuned Performance on this board does them but his sometimes hard to get ahold of.
If you delet the EGR then you won't need to swap the lower intake manifold, just make a block off plate for the egr tube on the rear of the intake.
Also if either of you would sell the complete vet large cap distributor (esp if it has the factory coil cover with bar code decal) let me know.
Car: 91 Camaro Z28/1LE & 91 SLP Firehawk
Engine: 350/5.7 L98 & 383/6.3 L98
Transmission: 4L60 Automatic & T-56 6 speed
Axle/Gears: G80/G92 3:42 & WS6 3:73
Hi All,
I know this is an older post but there’s not much about this swap. My question is:
Can you use the stock cast iron exhaust manifolds with the corvette aluminum head l98 swap in our cars?
Car: '89 GTA
Engine: ZZ6TPI
Yes, the exhaust manifolds will bolt up to the heads, however you will not be able to run the external EGR tube, if you are planning to keep the EGR system.
Awesome. Thank you GTA350, that’s exactly what I wanted to hear. I can always get the EGR block off cap & remove it from the ECU.
Car: '89 GTA
Engine: ZZ6TPI
Also need to consider the intake manifold or lower TPI base (whichever applies to your application). The aluminum L98 heads use the older 86’ and earlier intake bolt pattern.
Yes I have a brand new set of #113 casting aluminum heads and a brand new corvette lower TPI intake manifold base. I just need the EGR block off plate.
Thanks again!
Car: '89 GTA
Engine: ZZ6TPI
bjpotter
Jan 22, 2019 12:27 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Dialed_In
Aug 20, 2015 01:45 PM
