SBC balancer/pulley lt1 Accessories
Old Oct 18, 2015 | 12:24 PM
kyleiroc88's Avatar
Car: 88 iroc-z, 86 trans am
Engine: lt1
Transmission: 700r4 tci streetfighter
Axle/Gears: '02 10 bolt, slp auburn diff
Been wondering this for a long time... Can u put a gen 1 balancer/pulley on a gen2, or use gen2 Accessories on a gen 1 to make the SBC nice and short.
Or if running an electric water pump. Figured this would help someone.
Well the answer is yes. Tried a few crank pulleys like one off an c4 tpi better which is shortest SBC application. But that doesn't work.
March makes a serpentine crank pulley for a short water pump that originally had v belts. Used this and a balancer for an 88 350 Iroc on a 93 lt1 trans am. Had to use one small shim under the pulley. Just set an lt1 balancer/pulley on a table and compare the ribs on the SBC balancer and pulley til they match. Here are the parts:
http://m.summitracing.com/parts/mch-6211
http://m.summitracing.com/parts/aaf-all31066
It should also be noted the factory pass valve cover has a relief for the alternator made into it, so u may have to modify a valve cover if on a sbc
Old Oct 18, 2015 | 12:27 PM
kyleiroc88's Avatar
Engine: lt1
Re: SBC balancer/pulley lt1 Accessories
Should be noted this won't fit on an lt1 with the optispark in place. I deleted mine and the water pump and used a regular SBC timing cover to delete the holes. Lt1 and SBC use same timing cover bolt pattern, just the lt1 goes a little higher. had to weld a bit of sheet metal on top and drill holes for the 3 top lt1 timing cover bolts
Old Oct 18, 2015 | 09:44 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i'm not 100% sure, but you could have probably just used a timing cover from a newer 4.3 V6 with the balance shaft and saved some fabrication... or even just get some core plugs to plug the holes in the LT1 cover..
Old Nov 7, 2015 | 05:56 PM
kyleiroc88's Avatar
Engine: lt1
It was free and easy. And no the 4.3s are not the same.
Old Nov 7, 2015 | 06:01 PM
kyleiroc88's Avatar
Engine: lt1
Also I
hate when most people put a rear dist on the back of an lt1 intake it looks crappy where the egr stuff was. I just machined off the whole back and welded in a piece of angle. Much cleaner.
tbroherd
Nov 4, 2015 08:45 PM
mcweens
Oct 20, 2015 11:07 PM
Amir_t/a_78
Oct 17, 2015 06:45 AM
yellowferrari
Oct 15, 2015 03:45 PM
GMP318
Carburetors
Oct 14, 2015 08:14 PM
