What is this part above my oil filter?
Old Oct 27, 2015 | 08:46 PM
NerveKiller's Avatar
Hey all I just bought this 1991 camaro and did an oil change on it.
Seems this party directly above my oil filter is leaking quite a bit of oil.
Looks like some kind of sensor?
What is it called so I can replace it and try to stop this oil leak?
Its the silver thing above the filter. You can see a drop of oil dripping from it.<br/>What is this thing called?
Old Oct 27, 2015 | 09:16 PM
Re: What is this part above my oil filter?
oil pressure sender switch right? Im looking at it on rock auto and it appears to be the same switch.
Right now im wondering if this is the part that is leaking or maybe something above it. Anyone ever seen these leak straight through to the electrical connection?
Old Oct 28, 2015 | 07:31 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old Oct 28, 2015 | 10:01 AM
Damon's Avatar
Yeah, it's the oil pressure sender AND it acts as a secondary path for power to be fed to the electric fuel pump in the gas tank (that's why it's got 3 wires instead of just one).
Don't recall seeing one leaking straight through before, but it's possible, I suppose. Before you replace it make sure that oil isn't dripping onto it from above somewhere, though.
If your oil pressure gague seems to be giving "funny" readings (typically too low) it's about 80% probability that this sensor is the culprit. They're notorious for going bad.
Old Oct 28, 2015 | 10:48 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
oil pressure senders fail and leak though the body just like you are seeing, happens on jeeps all the time. a new sender should fix you up
Old Oct 28, 2015 | 07:14 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Yes, I had one leak through the wires before.
I also had a different Firebird have a small leak from the very back of the intake manifold from a cracked gasket that would run down (nearly unnoticeable) along the back of the block and then drip off the sensor.
I advise checking closely with an inspection mirror above the sensor and see if it looks good. If its dry, just change the sensor. It is pretty easy to swap out and I don't think it was expensive at all.
Old Jan 10, 2016 | 08:34 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
you can read my post on un-install/re-install of that very OPSU switch...should have all the info you need...do a search for OPSU install..or find my post...zero13
Old Jan 11, 2016 | 01:07 AM
Twin_Turbo's Avatar
Those things seem to be a very common oil leak, I have a couple and they all leak between the connector pinouts, I just replace them but they never seem to last very long.
Gunner242
Dec 25, 2015 04:49 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
