Failed Smog - What is this hose called?
Old Oct 28, 2015 | 12:38 PM
Caddywampus's Avatar
Car: 1987 Camaro Iroc Z
Transmission: Automatic
Axle/Gears: 3:27
I just tried to pass smog in CA and before my car went into the smog shop, the technician was asking about my car and he noticed this hose was all corroded and advised me to change it because it will fail inspection. He also said it idle's really high (1k) and that he needs it to drop down a few hundred rpm before he is willing to put it on the machine. The car was already warm because I drove it about 20 miles to get there so I guess it has a high idle right now.
On to the hose! Can someone tell me what this is called that is connected to the canister on the driver side towards the front of the vehicle? I looked in the service manual and it said something about an air purge hose or something like that but I cannot find a part number or anything on the search field. Is it just a simple vacuum line? If so, what size is the hose? Thank you for any help on this!
You can tell this hose is corroded somewhat
Old Oct 28, 2015 | 01:06 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Failed Smog - What is this hose called?
It goes from the lower port to the Canister
Old Oct 28, 2015 | 01:10 PM
Axle/Gears: 3:27
Hi Bob88GTA! Thanks for the reply! I already know where it goes but I was wondering what the hose is called? I need a new one and not sure if there is a part # or any vacuum hose will do. BTW nice engine bay
Old Oct 28, 2015 | 01:16 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks...mine is just a piece of Vacuum hose/original. There is no specific part # anymore. Just get some hose from auto parts store and run it over to the can
Old Oct 28, 2015 | 01:30 PM
Axle/Gears: 3:27
Thanks Bob! I will do that
Bubbajones_ya
Dec 27, 2015 11:14 PM
bjankuski
Nov 10, 2015 03:46 PM
Mike M
Oct 30, 2015 12:49 PM
Stank Bait
Oct 26, 2015 09:48 PM
budowski
Carburetors
Oct 10, 2015 03:28 PM
