92 Firebird gas tank removal?
Car: 88 Camaro
Engine: L98 350
Working on brother's 92 Firebird, fuel pump quit. He bought the car new, won't do the floor cut in that car. Got the exhaust system off, cross link bars off, shocks unhooked, rear end down as possible. Tank just won't come out. This tank has a relief area just over the rear pumpkin, helps but not enough. Any tricks to getting this tank out without removing the rear end? The fuel fill neck just won't clear. Thought about cutting the neck and rejoining with hose and clamps. Who the heck designed this mess, and with pumps that quit at 80k miles. Help!
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 92 Firebird gas tank removal?
the trick is having the rear axle down far enough . remove the brake hose first. laying under the car , you rotate and bring the right corner of the tank down first. it just falls out after that
Car: 86 IROC
Engine: 5.0 TPI
very good , now use the highest quality fuel pump you can get , so you dont have to do it again in 6 months
Engine: 4++,350 & 305 CIs
Just a FYI, that's a baffled 1LE tank, which became standard for all 3rdgens around 90-91.
The double sided fuel strainer is a tell tail sign.
Car: '89 Formula
Engine: L98 350
Got to do this in the next couple weeks. Never done it before. Should I be concerned with keeping the rear-end centered when I reinstall everything?
Car: 86 IROC
Engine: 5.0 TPI
KX3G. i see you are also in knoxville . should you need any help . im at 442 chickamauga. you cant miss it , there are 6. 3rd gen camaros here
Car: '89 Formula
Engine: L98 350
Car: '89 Formula
Engine: L98 350
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Doing this during the week this week. I was hoping to avoid disconnecting the rear brake line. Looks like there's no way around it?
Just have to remove the bolt that holds the T fitting to the rearend, that will let you bend the lines a little bit for more clearance.
Car: '89 Formula
Engine: L98 350
I need new hoses so I am going to replace them when I do the tank. Should give me more room to get the tank out.
yellowferrari
Oct 12, 2015 11:07 AM
