Ok honestly is there any way I can still run EGR with this setup??
Old Dec 20, 2001 | 11:17 PM
iroc22's Avatar
Ok I have a pair of '89 L98 Aluminum cylinder heads. I want to put them on my 305/TBI engine but I still want to run my EGR setup because I have to pass the sniffer test. Is there anyway maybe I can run the Corvette external style EGR maybe or will the SES light come on if I was to just leave the EGR valve hooked up to the vaccum line but not to the manifold?? please does anyone have any ideas
Old Dec 21, 2001 | 02:26 PM
iroc22's Avatar
what?? no ideas??
Old Dec 21, 2001 | 04:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What you need to do is fabricate an external tube a la Vette, but you can't use the Vette system directly.
I'm not completely familiar with the TBI manifold, but if like a carb type, you need to tap a fitting into the cross-over passage in the intake that feeds the EGR valve, similarly tap the exhaust, and run a tube between them. An insulating sleeve over the finished product is a good idea.
pimp2303
Jul 27, 2017 02:03 PM
ezobens
Aug 19, 2015 10:29 PM
Street Lethal
Aug 13, 2015 08:28 PM
camaroken83
Aug 10, 2015 11:35 AM
drathaar907
Aug 6, 2015 04:20 PM
