OK to use hydraulic jack on subframe connectors?
Old Dec 21, 2001 | 01:18 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I have a 2 ton jack and was wondering if I could raise my car using my SSM subframe connectors?
Thanks in advance, I didn't want to jack through the floor or anything!
Cheers
Old Dec 21, 2001 | 01:41 PM
pontiac's Avatar
better use spots where the sfc's are connected. in between it would bend.
-P
Old Dec 21, 2001 | 03:23 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
How do you mean? Anywhere along the subframe connector on either side?
Old Dec 21, 2001 | 03:25 PM
Damon's Avatar
I wouldn't. They're basically only attached on the ends and could be bent by pushing up on them in the middle. They're not designed to transmit force in that way.
Old Dec 21, 2001 | 03:27 PM
breathment's Avatar
i always have heard people saying the adding subframe connectors will GIVE you a place to jack since the stock places arent' that good.
Old Dec 21, 2001 | 03:47 PM
Jza's Avatar
Jza
SSMs are welded along the entire length of the rocker panel with stitch welds and with solid welds at the ends. I've jacked it up by the connectors with no problems. SSMs are like 10 gauge 2x3 rectangular steel tubing. It's tough shi+.
Old Dec 21, 2001 | 05:22 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
why don't you just roll your car onto a couple pieces of 2x4 to get it up high enough so you can jack up the front wheels and put them on a set of rims?
i did that with my '87 (put it up on rims) when i did my motor swap.. much easier
Old Dec 22, 2001 | 02:43 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
That's what I thought I had heard too! Just need to confirm it...
Otherwise where is the bset point for the front of the car with that jack?
Old Dec 22, 2001 | 03:02 AM
menace88SC's Avatar
Car: 87 Trans Am
Engine: 5 point slow LG4
i use a 2 ton hydraulic jack to lift my trans am and i have found that one of the most convenitent places to jack it up is under the lower A arm...i dont know if this is the best idea, but i havent had any complications from using my jack in this spot. but this is only a suggestion...for all i know, i have been using a less than adequate spot all this time.
peace,
menace
Old Jan 4, 2002 | 06:05 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Anyone else?
Old Jan 4, 2002 | 10:14 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Yea, if they're not installed correctly! I installed my own SSM SFC's and I stitch welded them from one end to the other to the rocker tab. When installing them, you definitely want as much bonding as possible! Why in the WORLD would you only attach the ends!? Strang stuff some people do...
I have been jacking the car from the balance point (about 2 feet back from the front of the connector). I even place the jack stands under the SFC's. I have been following this practice for YEARS with NO problems. The SSM's are WAY too strong to flex in a detrimental way under the load of jacking. So installing SSM SFC's DOES, in fact, give you another (better) place to jack and support.
Old Jan 4, 2002 | 10:35 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks Tom, thats just what I wanted to hear!!
Cool
gta892000
Aug 11, 2019 11:16 AM
Nervous2
Oct 8, 2015 10:53 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
