Shuts off an wont start
Old Jan 26, 2016 | 11:46 AM
Alexc299's Avatar
Hey guys i really need help i have a 1987 camaro iroc z28 the car runs fine its my daily driver just the problem is that when i come to a stop or im slowing down my rpms drop an my oil gauge drops to 0 and my car shuts off i crank it an crank it an wont start like if there is no gas so after a couple of minutes of it cooling off it starts right up i changed the oil pressure switch an sensor the egr the tps an nothing im wondering if its my oil pump what do you guys think???
Old Jan 26, 2016 | 02:48 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Shuts off an wont start
It's an electrical problem.
Getting any codes? is the problem more prevalent when it is hot out? (or, when you are running the heater on high??)
Old Jan 26, 2016 | 02:56 PM
Alexc299's Avatar
I actually havent scanned it i dnt have a abs to do it an its actually after i run it for a while that it happens or if im back an forth i move it like 5 feet an brake an it starts to bog an i have to rev the engine to where the oil gauge goes up
Old Jan 26, 2016 | 02:57 PM
ploegi's Avatar
Engine: 5.7 TPI
I would take a look at either ignition module, (getting hot, and failing) or ECM. (same reason)
Old Jan 26, 2016 | 03:01 PM
Alexc299's Avatar
You think the air flow meter has anything to do with it as well ?
stephenscamaro's Avatar
Car: 1988 Camaro
Engine: 2.8 to 383
EGR valve dirty? Check that out before you go too deep into tearing things apart.
Old Jan 26, 2016 | 03:02 PM
Alexc299's Avatar
I actualy replaced it a week ago
Old Jan 26, 2016 | 03:04 PM
Car: 1988 Camaro
Engine: 2.8 to 383
Does your oil have a slight gas smell to it?
Old Jan 26, 2016 | 03:12 PM
Alexc299's Avatar
You know what i actualy smelled it right now i asked my wife to smell it an it does
Old Jan 26, 2016 | 03:13 PM
Car: 1988 Camaro
Engine: 2.8 to 383
Check you injectors, o-rings and regulators out. Sounds like you might be washing a cylinder or two.
Old Jan 26, 2016 | 03:48 PM
Alexc299's Avatar
I will take a look at that
Old Jan 27, 2016 | 02:17 PM
Alexc299's Avatar
Hey i did the scan an i got code 36 and code 54
Old Jan 28, 2016 | 09:35 AM
Car: 1988 Camaro
Engine: 2.8 to 383
http://www.iroc-z.com/1987pages/1987...rouble%20Codes
Munyguy
Jun 5, 2016 10:21 PM
mz-man
Dec 3, 2015 08:53 PM
Nick McCardle
Dec 2, 2015 06:17 PM
bryan623
Nov 28, 2015 10:25 PM
bryan623
Nov 27, 2015 12:49 PM
