What length adjustable pushrods???
Old Feb 24, 2016 | 09:55 AM
Abubaca's Avatar
Normally have great success over at Summit, but I'm having a hard time finding adjustable pushrods, and ones I DO find have different ranges. I don't know the ballpark length I need to start with???
Can anyone recommend a set? I guess I just need ONE rod, right?
Old Feb 24, 2016 | 09:59 AM
Abubaca's Avatar
Re: What length adjustable pushrods???
This is on a machined block, aftermarket heads, custom grind cam....just trying to make sure I get the valvetrain set up properly.
Old Feb 24, 2016 | 10:36 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
7.2" would be my guess.
Old Feb 24, 2016 | 11:14 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
depends on what cam set up you are using
Old Feb 24, 2016 | 11:42 AM
Engine: LB9
Axle/Gears: 3.08
They are cheap enough, I'd get:
http://m.summitracing.com/parts/tfs-9000
I bought one years ago but haven't seen it since... If I can find it I'll send it you you at shipping cost. Edit: it's gone. Must have let some slacker borrow it.
Old Feb 24, 2016 | 04:01 PM
Abubaca's Avatar
Awesome. Thank you. ...and I appreciate the offer, even though it's gone!
Old Feb 25, 2016 | 06:09 PM
For most small blocks w roller cam, about 7.2 - 7.5" would be the range of interest. For a flat-tappet cam, 7.7 - 8". http://www.summitracing.com/parts/cca-7702-1/ will most likely do what you need.
Old Feb 26, 2016 | 10:45 AM
Abubaca's Avatar
Awesome. Thanks guys.
ydnar417
Feb 29, 2016 02:50 PM
Xzavior1818
Feb 27, 2016 09:53 AM
someone972
Feb 24, 2016 04:02 PM
92tealZconv
Feb 23, 2016 02:31 PM
CamaroChase
Feb 22, 2016 07:06 AM
