Blown head gasket??
Car: 86 Trans Am
Engine: 305 LB9
Blown head gasket??
In my previous thread I was asking about a radiator leak. The shop found the something hit it and cracked it causing it to leak. They also said my head gasket is blown. However it wasn't blown before this? The crack in the radiator shouldn't cause a blown gasket? I started it once without coolant to back it up for the tow truck and that was all. Immediately shut it off. How could this happen?
Car: 88GTA
Engine: 5.7TPI
Re: Blown head gasket??
They SAID your head gasket is blown.....what's the indication? Oil in coolant/ coolant in oil....what? Did you/they do a pressure test of the system? When you backed it up to the tow truck, was the engine hot/cold?
Just a few questions I had to ask.
If you were driving your car and the radiator cracked, pumped all the water out of the system, and you continued to drive it, yes you would have some issues. As in head gasket/engine seize and other catastrophic events. All which are not good.
Car: 86 Trans Am
Engine: 305 LB9
He said when I called that its was pumping out the exhaust lots of smoke, barely holding any coolant in it. No other words on oil in coolant or vice versa. Going there now to see it. The engine was dead cold when I started it in the morning for the tow truck
And no, It was running in the driveway while I cleaned the interior. Saw the huge puddle and shut it off and lifted it to check what broke. Seemed all normal that night except for the leak
Car: 86 Trans Am
Engine: 305 LB9
if it's that bad fill the radator with water leave the cap off and turn the car on if it's got a bad head gasket it'll shoot it back out of the radiator like to the hood shooting out
Car: 1990 Iroc z
Engine: 5.7 liter Tune port 383 stroker
Transmission: 5-speed
Axle/Gears: 3.45
Believe it or not, the motor will also over hear from the intake gasket also, my car also was in the garage for oh.... 2 plus years and in mechanics hands for several months not starting, does run, but installing parts here and there as we go on, long story short, installed some parts to it, and the intake gasket was taken off one day In order to install some parts to the motor, turns out several months later I forgot about it, but flash back that the intake was not properly seated right at all, and just a minor thing turned out to over heat the car after several miles or so, smoke threw the oil stick and just getting hot, can't figure out why??
New radiator, coolant, termastate, water pump, lower and upper hoses, even the Tpi unit where the water gets in threw and sometimes get clogged after several years, even got a burp part that allows tbr coolant to burp after all of these changes and still get hot and bogs out until after sitting for a few hours, head gaskets are fine... But yea turned out it was the intake gasket, still a job no question to get to it, because our motors are not of the norm, everything has to be removed to get to it,
Hope this helps!
Hope this helps!
Last edited by Johngypsy; Mar 2, 2016 at 10:55 AM. Reason: Correction spell is horrable
