Vortec Style Intake Gaskets
Old Mar 6, 2016 | 02:45 PM
skinny z's Avatar
I've tried several and while I can say I haven't had a failure, that doesn't mean that I won't this time around.
I've found these. The reviews are mixed.
GM Performance 89017465 (also sold as AC Delco 89017465)
FelPro MS98000T
FelPro 1255
FelPro MS90131-2
RHS 1707 (as recommended for their Pro Torker heads.)
Old Mar 7, 2016 | 12:30 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Vortec Style Intake Gaskets
I use FelPro MS98000T on all of my vortec head builds and never had a single problem out of them.
Old Mar 7, 2016 | 01:22 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i've used the GM gaskets and the identical in every way Dorman gaskets, and they both worked fine.. i did have to replace the GM gaskets, but that was my fault because i managed to break it in half when i had the intake off somehow..
Old Mar 7, 2016 | 06:03 PM
skinny z's Avatar
That's one I actually haven't tried. I like the looks of the metal core to go along with the silicone beading. One thing I don't like about it, and the similar plastic/metal carrier style gaskets, is that the intake ports aren't isolated from each other as there's no beading between them. No sure how that plays out into how the engine performs. You would think the vacuum would be messed up to some degree. I used to use them exclusively ( the MS90131-2) until I was convinced to try the Fel-Pro 1255.
Old Mar 7, 2016 | 06:14 PM
skinny z's Avatar
Looking further I see there's more than one gasket from GM. The 89017465 I quoted is from GM Performance. There's another domestic gasket, PN 12561347. Is that the one you're referring too? I haven't been able to find a direct to it on-line. There's also GMs 12529094 but I can't find a description or picture of that one either.
Old Mar 7, 2016 | 07:50 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Had an issue with the ones on my DD cracking and went with the felpro ones with the metal core. I have about 50k on them and no issues at all. The plastic ones cracked within 10k.
Old Mar 9, 2016 | 07:39 PM
skinny z's Avatar
Looking more like the MS98000T might be the way to go.
Interesting twist here is that with my heads getting milled, I may end up with intake alignment issues. The Fel-Pro 1255 I've had been using is .120" thick and that might be what I need for best fitment. If I recall, the typical plastic carrier gasket is only .060" compressed.
Does anyone have a MS98000T to measure? (That's the Fel-Pro metal core with silicone beading.)
Old Mar 13, 2016 | 11:11 AM
skinny z's Avatar
Originally Posted by skinny z
...Does anyone have a MS98000T to measure? (That's the Fel-Pro metal core with silicone beading.)
Anyone?
Further to that, looking at a closeup of the picture on the Fel-Pro website, it appears that there is beading between the intake ports. Can anyone verify that too?
Old Mar 17, 2016 | 08:51 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
They are beaded between ports and they are to the thick side but i dont have a number
Old Mar 17, 2016 | 08:54 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I just use the regular plastic ones... Never had a problem. Even reused one pair a bunch of times.
larsulrik
Mar 19, 2016 09:07 PM
Charlie113
Mar 10, 2016 02:49 PM
L98GTA87
Mar 4, 2016 07:04 PM
B4C5.7
Mar 1, 2016 10:01 PM
camarokid008
Feb 29, 2016 04:19 PM
