TPS VOLTAGE
Old Mar 28, 2016 | 10:06 AM
IROC AND ROLL's Avatar
TPS VOLTAGE
TPS (throttle positions sensor) at closed throttle it's not giving a reading (should be reading around 0.45v if I'm not mistaken) when I advance it a touch the lowest it reads is 0.80v However it has a steady climb to 4.45v wot with no mishaps, the car has a rough idle but when I'm on the gas it's smooth.
Old Mar 28, 2016 | 11:12 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: TPS VOLTAGE
If you have a dead spot, as you are describing, then you need a new TPS. Set at .54 at rest.
12doplumbing
Sep 1, 2019 03:06 PM
Jan1980
Apr 3, 2016 12:28 PM
jjjosh
Mar 27, 2016 07:53 PM
thebossmanscot
Mar 27, 2016 11:11 AM
inkscape
Mar 23, 2016 04:00 PM
