No crank no start issue
Old May 16, 2016 | 05:22 PM
nick72583's Avatar
So last year I parked my car to resume working on the body since I bought another vehicle and recently tried to start if and nothing. I've checked the relay and it's functioning properly and the vats system is as well. There is no security light on so I am just wondering if I am overlooking something or if it's just the starter? I turn the switch and nothing happens at all. The solenoid doesn't click, nothing. Any ideas or does it seem like the starter to everyone else as well? I hope I posted correctly this time, I'm new here so...
Old May 16, 2016 | 08:49 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: No crank no start issue
Is the purple wire on the starter getting power when you turn the key to start? That will tell you if the starter is getting signal to turn over.
Old May 16, 2016 | 08:55 PM
nick72583's Avatar
Yeah it's getting power. I decided to check my neutral switch and after messing with it I was able to get the starter to turn. Problem is now it's making a grinding noise while attempting to crank ( still not turning over but starter is engaging.) I'm kinda leaning toward the starter not fully engaging but not positive if it could or couldn't be anything else.?
Old May 16, 2016 | 09:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Are you sure the battery is fully charged? Wouldn't hurt to load test it (after it's fully charged).
Old May 16, 2016 | 09:37 PM
nick72583's Avatar
Battery isn't fully charged and I'm having to jump it. Think that's what's keeping the starter from fully engaging?
Old Jun 28, 2024 | 09:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Anyone consider that the solenoid is failing since u have the click, click then a start?
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
Bryanm254
Mid-West Region
Apr 1, 2016 12:31 PM
Derbicus
Mar 27, 2016 04:11 PM
cannibaljeri
Mar 20, 2016 02:26 PM
That Sky Guy
Mar 15, 2016 07:40 AM
