Not starting and a weird issue
Old Sep 8, 2016 | 07:33 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
So I did the tach/speedo fix following the thread on the electronics forum and thought I would post here too just in case.
I did the fix, put the bezel and gauges back on, went to start the car and nothing. No clicks from the battery, no lights, and no buzzing/or ringing.
First thought was the battery was dead. Left it on the charger for several hours, hooked it back, and still nothing.
Didn't touch anything with the wiring and the harness is brand new. The car started up just fine prior to this.
Any thoughts???
Old Sep 9, 2016 | 05:04 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Not starting and a weird issue
Is this on the LS swapped 91 in your info section?
Check the main grounds off the battery and engine, and the power junction block, also see that your battery terminals are clean and tight.
Old Sep 9, 2016 | 08:16 AM
Ikes 91Z's Avatar
Yeah its the ls swap.
The grounds were the first thing I checked last night and they all had good connections. The battery and cables are both brand new so there is no corrosion etc.
Old Sep 9, 2016 | 09:42 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
What was the tach/speedo fix? Maybe the wires for the ignition switch got disconnected if you were under the dash.
ignition switch would probably be the next thing to check.
So you pulled the gauge cluster, and now nothing happens when you turn the key(no dash lights). do your headlights still come on?
Old Sep 9, 2016 | 09:51 AM
Ikes 91Z's Avatar
The tach fix was soldering a 200k resistor on the circuit board. The speedo fix was soldering a 30ohm resister and a 150v capacitor on the circuit board. Pretty straight forward fixes.
I removed the bezel, the plastic 'glass' in front of the gauges. The only wiring I touched was the Foglight switch, the cig lighter, and the small connector on the speedo circuit board.
I didn't touch any of the wiring around the ignition switch, and there weren't any exposed wires when the cluster came out.
I do not have headlights either. Literally, nothing is happening when I turn the key.
Old Sep 9, 2016 | 03:33 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Still thinking a bad ground off the battery.
When you did your swap did you incorporate a power junction block, or is everything still tied onto the main starter terminal?
Old Sep 9, 2016 | 04:54 PM
Ikes 91Z's Avatar
Pocket did the harness and has about 5 power leads on it that I tied into the positive side of the battery. I've started the cat up 25 times at least. This only started after doing the tach.
Old Sep 9, 2016 | 05:25 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Nothing in the gauge cluster would shut off everything like that, it's probably just coincidence that it happened after fixing the cluster.
Old Sep 9, 2016 | 08:08 PM
Ikes 91Z's Avatar
Agreed. I plan on removing all the battery cables, and cleaning everything (again) to ensure good contact (again).
I'm gonna try and get it in tomorrow afternoon. Hunting season is rapidly approaching and I need to keep getting deer camp setup
Old Sep 10, 2016 | 11:27 AM
Ikes 91Z's Avatar
Grounds all good. Fuses all good. Battery showing just under 12 volts.
No clue. Frustrated as hell.
Old Sep 10, 2016 | 03:07 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Do you have power on any circuit? Do you have 12 volts at the starter terminal, or 12 volts at the alternator? Have you ohm tested your main wires and ground wires for excessive resistance?
No battery kill switch you wired in for racing and have it turned off
Old Sep 10, 2016 | 03:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you're reading voltage with anything other than the dash gauge, your battery is dead.
You disconnected the battery before pulling the gauge cluster, yes?
Old Sep 12, 2016 | 07:30 AM
Ikes 91Z's Avatar
I did unplug the negative cable before pulling the gauge cluster. Interestingly enough though, the battery was shot (it's about 4 years old).
When I went to plug the new one in, I've got a wire shorting out somewhere because it was sparking like crazy and melting the contacts on the negative terminal. So now I get to chase down that gremlin.
I've already checked all the battery cables to make sure nothing was touching since I had been messing with those a lot, and yes, the positive is on the positive and vice versa
My thoughts are the wiring behind the passenger header might have melted. I don't think anything in the cluster would make it ground out that bad, but we shall see.
Old Sep 13, 2016 | 07:51 AM
Ikes 91Z's Avatar
Well, got it narrowed down to the alternator. Somehow it is grounding out at that post.....sometimes. I first hooked it up and had it without grounding, and started the car. I got back under to tie up loose cables and clean it up and it started grounding out again.
I have the racetronix hot wire kit, so I need to see if something on that is causing the short.
91phoenix
Fabrication
48
Jul 22, 2021 06:01 PM
CarGuyDennis
Oct 19, 2016 08:29 PM
19irocz85
Aug 31, 2016 02:28 PM
Anthony0128
Aug 26, 2016 07:17 PM
Anthony0128
Aug 12, 2016 11:51 PM
