Block coolant drain plug....
Old Nov 10, 2016 | 11:33 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
It's located on the block forward of the oil filter. Up until recently, I didn't even know it existed.
About 3 or 4 years ago, I walk into my garage and see a gallon or two of coolant under my '85. I freaked out!!
It turns out the drain plug had loosened. How that happened, I have no idea. I tightened it, topped off the coolant and that was that.
Until now, I noticed a couple drops of green on the garage floor. It turns out it's the same plug. I tightened it but appears to be weeping slightly. What gives?
Has anyone had any trouble with this thing? Why would it loosen and what did you do about it?
Old Nov 11, 2016 | 03:53 AM
Re: Block coolant drain plug....
Probably not "loosening". More likely, corroding.
Replace it. ¼" pipe. Get a brass one at Home Depot or something. Make sure it's the kind with the LARGE hex head; not the small square head, not an Allen.
Old Nov 11, 2016 | 06:12 AM
chazman's Avatar
Axle/Gears: BW 3.45
Any sources for a factory replacement drain plug? I haven't been able to find one.
Old Nov 11, 2016 | 08:31 AM
Home Depot
Old Nov 11, 2016 | 10:57 PM
chazman's Avatar
Axle/Gears: BW 3.45
Home Depot
Gotcha.
Well, if there is a way to screw this up, I'll probably find it.
So let's review: 1/4", brass, large hex head. Any thoughts on best length?
Old Nov 11, 2016 | 11:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
IIRC, its about 1/2 long total
Old Nov 12, 2016 | 09:33 AM
gt4373's Avatar
Transmission: 5-Speed Manual
If You Can't Find One In Home Depot,They Have A Factory One Here But The Shipping Is Twice The Cost Of the Plug.
http://www.ebay.com/itm/1-4-NPT-Engine-block-Drain-Plug-SBC-BBC-350-396-427-454-V8-Auto-Farm-PP745-2/301125956504?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D38530%26meid%3D3f4810eb3f5445dbac0013247c52e5bb%26pid%3D100033%26rk%3D1%26rkt%3D3%26sd%3D301125956504
Old Nov 12, 2016 | 09:39 AM
chazman's Avatar
Axle/Gears: BW 3.45
http://www.ebay.com/itm/1-4-NPT-Engi...3D301125956504
Freakin' awesome! Thanks!
