Will SBC Vortec heads fit on an older engines.
Thinking about rebuilding my old 1967 300 hp 327 but using newer Vortex heads. I know that they require a matching intake manifold. Will they bolt on directly or does the block have to be modified? I would like to use this engine in my 1989 RS Camaro. I would be using my old 348 tri-power carb setup with progressive linkage on an Eldenbroc air gap manifold for vortex heads.
re: Will SBC Vortec heads fit on an older engines.
Yes they are a direct bolt on except for the intake.
They have 64cc chambers. Though many report they measure in at 66cc if they haven't been cut.
GD
GD
Transmission: 4L80E/4L80E
Re: Will SBC Vortec heads fit on an older engines.
A real 300 horse 327? I'd be tempted to sell it to a restorer and use the proceeds to buy something else.
But, as the General stated, they will bolt on to any Gen 1 SBC (will not work on LT1 style blocks).
By the way, it's "Vortec", not "Vortex". I changed the thread title for you.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
sell the 327 to someone who needs it, and build a 350. For that matter go to your local parts yard and get an entire roller cam vortec engine. Free horspower is what roller cams are.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Application Dyno Emissions Satin Polished Black EnduraShine
RPM Air-Gap Vortec (non-EGR) - 7516 75161 † 75163 75164
http://www.edelbrock.com/automotive/...r-gap-sb.shtml
Opps missed that here is the nnon airgap version. Don't think they make an air gap
edelbrock 5417
http://www.edelbrock.com/automotive/.../5000/5414.pdf
edelbrock 5417
https://www.summitracing.com/int/sea...illocation=int
There is a 2 x 4 Air Gap available though.
https://www.summitracing.com/int/par...7526/overview/
EDIT: I see I'm a little late to the party...
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Stupid auto-correct...
Johnny*G
Oct 20, 2017 01:26 PM
SilverChicken
May 5, 2017 03:23 PM
