what did you do to your thirdgen today?
Old Dec 18, 2019 | 01:57 PM
  #1001
QuentsIROC's Avatar
Car: 1986 IROC-Z
Transmission: 5 Speed
Re: what did you do to your thirdgen today?
Originally Posted by QuentsIROC
Bought a crate 350 from Precision Engines through Summit (free shipping from Summit, Precision charges $200 to ship). 373 horsepower rated. Dyno sheet shows 396.5 hp and 415 foot lbs torque. New clutch, pressure plate, t.o. bearing, pilot bearing, and flywheel coming tomorrow, plan to install everything tomorrow night.
Had a local "race engine guru" build the last 350 that was in it back in 2008. Put @ 10K miles on it before it wiped a lobe on the cam a couple weeks ago. Pulled the engine, checked all numbers, heads are junk 305 heads from a late 80's f-body car. Not even Vortec heads like the guy said they were. Got reamed, lesson learned. Engine never did run that great which I've been fine with as my son has been driving it. I honestly believe the original 180 hp 305 in the car ran better than this last one. Can't wait to put ~400 hp to the tranny in a couple days!
Here's pics of car that I've posted before.
UPDATE: just passed the 500 mile break-in on the BluePrint engine. All I can say is wow, this motor screams. My 17 y.o. son (very responsible kid) drives it as his daily so I had a conversation with him about the power it has and that he needed to keep it under control and stay out of trouble as walking isn't crowded. After the first day he drove it he comes home and says, "Dad, you're not kidding about the power difference. I was at a stoplight and started to take off and it started to die on me (5 speed) so I did what I always have and punched the throttle 3/4's of the way to the floor to get it going. The rear end broke loose and tires were howling, I can't imagine what it'd do if I held the throttle all the way down!"
I was a little skeptical when I ordered the engine because of some negative reviews I've read about BluePrint engines online, but I can honestly say I'm tickled I got this. GREAT power, seems very reliable, no issues. Power comes on hard at around 2500 RPM and it roars up through around 6000 to 6500 RPM (dyno sheet showed highest HP at around 6000 RPM). Best decision I've made with this car other than buying it twice.
Old Dec 18, 2019 | 03:55 PM
  #1002
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
that is a beauty,looks perfect just the way it is and with a little extra power !!!
Old Dec 19, 2019 | 10:01 PM
  #1003
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Tried a thermal wrap on the starter to hopefully help hot start issues. Failed miserably. Wasted $19. Will try solenoid relocation next.
Old Dec 20, 2019 | 04:44 PM
  #1004
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
do you have long tubes and a regular sized starter?if you do that is your problem,you need a mini starter.Dont throw away the insulation,it will help when you get a better starter.
Old Dec 20, 2019 | 08:51 PM
  #1005
NoEmissions84TA's Avatar
Originally Posted by Handy_man91
I just noticed in your picture that you seem to have the CORRECT throttle & TV cable bracket.
Who makes it, what's the part number, and any other pertinent info, please........... Also some close-up pics if you would. Thanks.
You could post the reply to this post: https://www.thirdgen.org/forums/carb...e-bracket.html
Old Dec 20, 2019 | 10:06 PM
  #1006
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Spent the evening removing the ttop weatherstripping from my 90 formula. Its been leaking horribly to the point im seeing rust stains on the plastics and water is running down the inside of the windshield. Im not sure I will be able to save the ttop bar as it has rust but i was surprised to see the channels in good shape considering the amount of water. Once this is complete i will get the windshield re sealed.
Old Dec 21, 2019 | 11:25 AM
  #1007
Handy_man91's Avatar
Car: 85 firebird
I plan on doing a full write up with pics, almost there. Your not the first one that's asked. But it's a modified Holley bracket (easy mod, will cover it, no welding)
Old Dec 21, 2019 | 02:57 PM
  #1008
I can't wait to read it. Thanks.
Old Dec 21, 2019 | 08:23 PM
  #1009
Carlos89's Avatar
Car: 1986 Trans Am
I have shorty headers and a factory starter. Ii thought I'd try the cheaper fix first BUT what mini starter do you recommend? And thanks for helping me out bro.
Old Dec 21, 2019 | 09:21 PM
  #1010
The hot ticket is the 92-96 Corvette LT1 starter.
Old Dec 21, 2019 | 10:29 PM
  #1011
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
no emmisions84ta has a great suggestion and ive heard other lt1 starters are also smaller and more suitable.im getting closer to being ready to install a 350 with shorty headers and ill be dealing with the same thing so let me know what you find works.i just missed out on a used mini starter (also a solution apparently)because of lack of funds/procrastination.
your car is looking great by the way,keep it up.here is my before and after engine detail.
this is before:
before (wow,its horridly ugly)
this is after...
and now im going to do a vortec headed 350 swap(plus gmpp roller cam,edlebrock rpm intake,holley 650 ultra double pumper,hooker shorties,and aluminum everything)
almost ready.350 roller block with vortec heads
Old Dec 21, 2019 | 10:30 PM
  #1012
Car: 85 firebird
Got it done, it's posted in the carb forum
Old Dec 21, 2019 | 10:49 PM
  #1013
rburrow87's Avatar
Car: 1975 Pontiac Firebird Formula 400
Engine: SBC 350 w/Pro-Flo 4
Transmission: M29 T56
Axle/Gears: Stock 10 bolt w/3.42 and new Auburn
F/B-body LT1 starters are good too. I run a $60 eBay special LT1 starter (includes new bolts!) and its been pretty good so far, going on 2 years.
Old Dec 22, 2019 | 06:46 AM
  #1014
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Worked on my buddy's 3rd gen today. We started his engine bay clean up. We started to remove the air pump system. He has no cats already so the air pump system is 50% useless so we just will get rid if it. We repurposed the rubber heater hose that went around the back of the engine to tie in the 2 sides of the air system together. He wanted the heater control valve to be off the valve cover and as you see it was a perfect bend to put it right next to the coolant tank. Hopefully when we are done it will look as nice as Bandit's transformation posted above.
Anyone interested in some original air pump system?, minus the hose!
Old Dec 22, 2019 | 12:26 PM
  #1015
Carlos89's Avatar
Car: 1986 Trans Am
Thanks and that looks great man!
Old Dec 22, 2019 | 12:28 PM
  #1016
Carlos89's Avatar
Car: 1986 Trans Am
Thanks man
Old Dec 22, 2019 | 12:29 PM
  #1017
Carlos89's Avatar
Car: 1986 Trans Am
Thanks bro
Old Dec 22, 2019 | 11:56 PM
  #1018
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Old Dec 23, 2019 | 05:53 AM
  #1019
vinny R's Avatar
Car: 1991 Z28
Originally Posted by 84 1LE
That is looking sweet! what vehicle is the new handle from?
Old Dec 23, 2019 | 10:10 AM
  #1020
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks, Mid 90s caddillac.
Old Dec 26, 2019 | 10:03 PM
  #1021
Swapper's Avatar
picked up a set of lightly used flex a lite fans for $75. oh and got my motor out of machine shop prison after 2 months. cant wait to start putting everything together. just need to get my buddy to build my headers.
Old Dec 27, 2019 | 03:58 AM
  #1022
ROONEY's Avatar
Car: 89 IROC Z
Engine: 5.7ltr
Transmission: Hurst 400
Well I finally got around to putting in and connecting up a pod of 3 gauges, volts,water temp,oil pressure very simple to do, just takes really a couple of days to do (relaxing days) with the oil pressure gauge tho when i first turn the key on the needle goes to the 7 kg untill i start the car then it drops back to just under 5kg which i think is about 60 psi,is this how it should be?
Old Jan 1, 2020 | 02:14 AM
  #1023
Moonlight137's Avatar
Car: 1992 RS
Engine: L03 / MSD / 2½" "hacksaw" catback
Transmission: 4L60
My suspension seems wobbly, can't find anything wrong in the front, so I pulled back the carpet and took out the foam pads to look at the rear shocks. There's some residue from the foam still stuck to the bolts, and after a minute I figured out that means my shocks are 28 years old.
Old Jan 1, 2020 | 11:22 AM
  #1024
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
my suggestion is dial in your brakes,suspension and make everything right,then do tasteful mods
that help performance and looks.proper performance exhaust definitely helps especially with headers,just
gutting or removing the cat does next to nothing unless it was blocked.
Old Jan 1, 2020 | 11:25 AM
  #1025
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
don't the sweet gauges in the car from stock already work?
Old Jan 1, 2020 | 03:40 PM
  #1026
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Done...for now.
Old Jan 1, 2020 | 06:00 PM
  #1027
vinny R's Avatar
Car: 1991 Z28
Nicely done. I always thought these cars would look good with flush handles.
Old Jan 1, 2020 | 07:30 PM
  #1028
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yep, and theyre much better made than the flimsy stock pieces of ....!
Old Jan 2, 2020 | 02:52 PM
  #1029
ROONEY's Avatar
Car: 89 IROC Z
Engine: 5.7ltr
Yeah right the oil pressure gauge: ah no the needle would just flick around on start and jam on the edge ,but i connected the new gauge using the same sensor and sweet as,the original temp gauge didnt work at all ,and dont ask me what the tach gauge does .
i also got around to replacing those dam rattling door handles because of broken springs and replaced the locks with black ones
Old Jan 5, 2020 | 08:53 PM
  #1030
Car: 1992 RS
Transmission: 4L60
Tranny mount.
Wait, those are supposed to be one piece?
Then I got what we patio mechanics sometimes describe as a "wild hair," and scraped most of the 28-year-old grease off the transmission pan and the crossmember.
Old Jan 6, 2020 | 05:11 AM
  #1031
rgauder's Avatar
Car: 1987 Trans Am
Made a couple of hubs out of 1LE rotors for my Big Brake Upgrade. Shouldn't have to use spacers with my wheels this way. Boy was there a lot of cast iron chips to clean up, lol.
Old Jan 8, 2020 | 01:13 PM
  #1032
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Installed a heater core!!!
https://www.thirdgen.org/forums/cool...ater-core.html
Old Jan 8, 2020 | 05:54 PM
  #1033
EnglishFirebird's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 v6
Transmission: Automatic
I tried and failed to re-connect my Walker y-pipe to my catalytic converter where it has come loose and leaks fumes and noise, and sometimes comes completely apart!
It was not fitted right by the garage in the first place, there is barely 1cm of overlap and for some reason seems to have 2 u-bolts on it... I tried to tighten one and could do so, but it barely made any difference and I worried about over-tightening.
Will be taking it to a specialist custom exhaust place next Thursday, meanwhile I am daily driving a car that sounds terrible or even worse if it comes undone..
Old Jan 9, 2020 | 01:40 AM
  #1034
Swapper's Avatar
got my heads back. put the ls9 head gaskets, arp studs, spec clutch and rebuilt trans all together then threw it in the car. threw the intake manifold i bought on and realized i want a different one. so its up for sale/trade. need to order some sensors and gaskets then start wiring it up. gotta figure out where to mount the holley dashes.
Old Jan 13, 2020 | 09:06 AM
  #1035
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Installed an oil catch can
Old Jan 13, 2020 | 03:57 PM
  #1036
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
yeah,thats not something you can fix with clamps and adapters unfortunately.
Old Jan 13, 2020 | 05:32 PM
  #1037
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
Transmission: 700R-4
Axle/Gears: 273 posi trac
Old Jan 13, 2020 | 05:39 PM
  #1038
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
So many awesome third gens on here.... Mine pales far by comparison but maybe one day I can get one of mine to look as good as some of the ones here in these pages. Keep up the great work you guys, your cars are truly an inspiration!!
Old Jan 19, 2020 | 02:59 PM
  #1039
Car: 85 firebird
Got some new junk yard seats, my old ones were full of cigarette holes front and back (thanks po) . Decided while I had all the seats out would be a good time to shampoo the carpet. Didn't do much for the stains but sure smells alot better in there. Killed the 30 year old must&dust smell.
Old Jan 19, 2020 | 07:46 PM
  #1040
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
ive got a pair of these in my closet(and a pair of 2012 camaro seats as well) im rocking some grey gta seats now that are super mint
Old Jan 19, 2020 | 07:49 PM
  #1041
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
it only takes time and hunting for parts,ill get there eventually too!
Old Jan 19, 2020 | 07:50 PM
  #1042
Car: 85 firebird
I like that hood , there's one where I pulled the seats. Guy wants 200 for it, going to grab it soon as I have the funds, provided he still has it.
Old Jan 19, 2020 | 08:23 PM
  #1043
Car: 1992 RS
Transmission: 4L60
The new shock is held closed/compressed by the wire you can barely see. The 28-year-old one is mostly just laying there.
It expanded some after about five minutes. The one on the other side did nothing at all.
Old Jan 19, 2020 | 08:47 PM
  #1044
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
move quick,they are double that new and hard to find from what ive seen in my area.is it steel or glass?
Old Jan 19, 2020 | 08:54 PM
  #1045
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
gathering more parts and waiting for it to not be a winter wonderland outside and partially in my uninstalled,unheated garage.
picked up:
grant challenger steering wheel $20
comp cams retainers(new)
ls6 beehive springs $30
viton valve seals(new)
stainless braided fuel and other braided lines 1/2" id and 3/8" id -14' and 10.5' rolls nos($50)
1 1/2" rim spacers for my bbs lm reps $40
Old Jan 19, 2020 | 10:35 PM
  #1046
Car: 85 firebird
Fiberglass. Has a few chips along the front edge but other than that just needs paint. Bolt areas for hinges are solid.
Old Jan 20, 2020 | 01:10 AM
  #1047
Swapper's Avatar
been mostly doing some wiring. did a sorta wire tuck on my headlight harness. did some wiring on my holley stuff. mounted up these cheap caster/camber plates. need to pick up some springs from my buddy to put my front suspension back together. finally decided that i really need a dual pass radiator but just need to find one thatll fit with an a/c condenser. got some of my fuel line and fittings. ordered some filters and mounts. need to order a regulator and fuel pump. trying to sell my vic jr intake manifold to get a different intake. bought a nearly mint dash pad for .99 cents plus $75 shipping. should be here monday. also looked into repairing and flocking this other dash pad i have.
Old Jan 20, 2020 | 07:47 AM
  #1048
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Crazy how expensive dash pads are.
Old Jan 20, 2020 | 07:46 PM
  #1049
Swapper's Avatar
yeah. dude had 3 of them. 2 at no reserve or starting bids. i bought one and my buddy bought the other, then after we bought the, he listed another one with a starting price of $100.
anyways got my u-joints pulled off my ls1 driveshaft, modified my fuel pump sending unit to run thicker gauge wiring.
Old Jan 20, 2020 | 09:24 PM
  #1050
Evilokc's Avatar
Engine: tbi 305
drove it to work after fighting a charging issue for almost a month
