what did you do to your thirdgen today?
Old May 3, 2018 | 07:33 PM
  #401
2 birds 1 Z's Avatar
Car: 2002 Firehawk & ws6 1989 Iroc Z
Engine: All 3 have 350s
Transmission: Birds manual Iroc auto
Axle/Gears: TAs 342 & Iroc who knows?
Re: what did you do to your thirdgen today?
Yes Sir, I saw that I might have to get the whole enchilada. I have no problem with that, but I want to see if I can just get the plastic. I have a replacement mirror all set to go. I old one was scratched up. Had to go.
Old May 3, 2018 | 07:37 PM
  #402
I'm gonna try some silicone spray. See it that makes it pop back in any easier. I hope, because I want to drive it again. Yes, the mirrors are powered.
Old May 3, 2018 | 08:57 PM
  #403
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Bangin. Good luck.
Old May 7, 2018 | 04:31 PM
  #404
Grabbed the whole mirror from Hawks Motorsports. Was having no luck just getting the plastic. Are the motors interchangeable from side to side? I got a driver's side that I'm scarfing the plastic & mirror glass if it's pristine. Otherwise, nos glass is ready to go.
Old May 7, 2018 | 04:40 PM
  #405
The SEM trim black is a perfect match. I Scuffed up the tabs good with a green Scotch Brite pad. Then used the self etching primer, which is black as well. See for yourself. I have to give thanks to Chris & his '89 red iroc build on Facebook for the suggestion.
Old May 7, 2018 | 05:51 PM
  #406
https://www.facebook.com/1989Iroc/photos/a.920715174674903.1073741847.916797081733379/1092069707539448/?type=3&theater
Old May 7, 2018 | 09:28 PM
  #407
Abubaca's Avatar
...and good job!!!!!!
Old May 7, 2018 | 09:31 PM
  #408
You're welcome & thank you. Hey, wait a minute, did I get that backwards?
Old May 12, 2018 | 12:10 PM
  #409
Success on the 2nd attempt to remove the plastic backing & mirror from a donor assembly. The factory used 3 dollops of adhesive to mount the glass to the backing. The new replacement glass has 2 strips of tape.
Had to pirate one of the locator things from the cracked one.
New glass ready to go in after an alcohol bath is given to the plastic. Want it clean for good tape adhesion.
Sacrificial scratched glass.
Old May 14, 2018 | 11:05 PM
  #410
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
I added some Rislone ZINC additive and stared at it for 5 minutes lol
Dave
Old May 15, 2018 | 12:21 AM
  #411
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I gutted my next build :-)
Next need to figure out the blasting situation...probably should have had an idea before getting to this point lol. Oh well.
Attached Thumbnails what did you do to your thirdgen today?-20180513_225101.jpg   what did you do to your thirdgen today?-20180508_194956.jpg
Old May 15, 2018 | 06:57 PM
  #412
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Just got my third gen. Can't wait to mod it some. Have to sort out the exhaust first.
by https://www.flickr.com/photos/62639173@N03/, on Flickr
Old May 15, 2018 | 07:49 PM
  #413
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Looks sweet Boom! Congrats on the thirdgen!
Old May 15, 2018 | 08:14 PM
  #414
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Thanks! I've always wanted a clean third gen and now I have one.
I'm used to restoring/working on first gen Mustangs (64-70) and I gotta say the aftermarket supprt for third gen parts is alot smaller. You can literally order every single nut/bolt/bracket/widget for those Mustangs.
Old May 15, 2018 | 09:24 PM
  #415
Hey Boom, if you ever want to sell your '88-'90 wheels for the correct style, let me know. I will pay your price.
Old May 18, 2018 | 07:30 PM
  #416
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Thanks for the offer. I'll have to look at the correct style for 86 and see. Still learning about these cars and SBCs.
Been working on fixing a few odds and ends. I had a leak from the fuel pump. Turns out whoever installed it didn't use a gasket/RTV or anything. I cleaned it up and installed the proper gaskets. So far it seems to have fixed the leaking.
My battery is just chilling here in the corner, it also looks like a battery could go on the drivers side. Which side is correct? Either way I need to get the mounting hardware to secure it.
I had to pull the driver's valve cover off because some knobgoblin installed it upside down (Edelbrock script). Found out I have to remove the wiper motor to get the cover off. Looks pretty clean under there though. Installed a permadry gasket when I put the cover back on.
EDIT: Not sure why my pics are double posting, it only shows once in the edit box.
Old May 18, 2018 | 08:17 PM
  #417
Brett, here is a link for the correct wheels for your '86. They are correct for '85-'87.https://www.google.com/search?q=85%3...RZ9DUYQsAQI8gE
Old May 18, 2018 | 08:22 PM
  #418
This is what came on your car from the factory.
Old May 28, 2018 | 11:41 PM
  #419
Ordered a nice & shiny new driveshaft to replace the rusted one that’s on the car. It came from the NE, so I’m figuring it saw some snow & salt.
Old May 30, 2018 | 09:51 PM
  #420
punzak9's Avatar
Car: 1990 Firebird Formula
Engine: 305 V8
Had to change the thermostat in the Formula, so after that I decided to wipe everything down real quick and give it a little cleaning.
Old May 31, 2018 | 07:02 PM
  #421
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
haven't posted in a while. I'm not really working on anything. ive just been driving the wheels off of it. I'm working at a location that's putting about 85 miles a day on it. 85 miles at 80mph is nice. ive known for a while that my suspension needs some love. i heard a ball joint clicking yesterday. guess that next.
Old Jun 3, 2018 | 08:04 PM
  #422
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Looks great!
Old Jun 5, 2018 | 09:56 PM
  #423
Well, I finally got the driver's side mirror replaced. Before I taped the glass to the plastic, I generously applied silicone spray to the plus sign on the back of the plastic as well as the clips that it plugs into. Lined up the screw looking locators & pressed hard. Nothing. Took my finger tips & pecked it hard. Success. Then I doused the plastic face with alcohol in prep for good tape adhesion. New glass fits perfectly, like factory glass.
Old Jun 5, 2018 | 10:01 PM
  #424
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Took my ttops out for a 12 minute ride home but man I looked cool for 12 minutes!<br/>
Old Jun 5, 2018 | 10:23 PM
  #425
Custom made fit to order sunscreen for my '89 Iroc fits like a glove. Thicker than the cheap ones you can get from the parts store, that don't fit real good.
Covercraft exact fit sun shade.
Old Jun 6, 2018 | 09:40 PM
  #426
Got my new driveshaft for the Iroc today. Have to get the car up in the air to do the swap. Stock shaft is big time rusty, it was a northern car. While under the car, I will take an inventory on all the rusty pieces.
Old Jun 9, 2018 | 12:13 AM
  #427
While looking under the car in prep for the driveshaft swap Saturday, I noticed I now have a small oil leak. Gotta try to find the source & nip it in the bud.
Old Jun 10, 2018 | 03:35 PM
  #428
Toxicant's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.23 4th Gen w/ powertrax locker
Finished up repairing my trunk pan.
Old Jun 10, 2018 | 03:48 PM
  #429
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Finished my LS1 fan install. Works much better then the old single fan.
Old Jul 22, 2018 | 09:55 PM
  #430
Evilokc's Avatar
Engine: tbi 305
im making a list of mechanical things to start working on. I still haven't fixed that ball joint.. drive the thing constantly though. hard to take it apart when its moving all the time. did they make any upgraded a/c fans? mine works on all setting but it really seems like it could blow harder.
Old Jul 23, 2018 | 11:05 PM
  #431
Per thread title, I looked at pics of mine. Can't appreciate it's full beauty sitting in the garage.
Old Jul 24, 2018 | 06:16 AM
  #432
Vader's Avatar
Charged the battery some more.
Old Aug 6, 2018 | 07:45 PM
  #433
88IROC-USA's Avatar
Car: 1988 IROC-Z
Transmission: 700-R4
Axle/Gears: 2.77 Positrac
Two weeks and two (guaranteed) salvage compressors later, a manifold assembly, a high pressure switch, a low pressure line, a "retrofit kit" (for 134A conversion) annnd a new dryer with orifice tube later.....the IROC has A/C!
I spent about $260. 👍
All we need now is moar Fan Speed LOL!
Old Aug 6, 2018 | 08:29 PM
  #434
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
I roasted another set of rear tires
Old Aug 7, 2018 | 07:47 AM
  #435
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Let my 14 yr old change distributor cap, rotor, and most of my plug wires. Saturday coming in from a cruise in the car had developed a bad miss. Wound up being a plug wire had came loose from the loom and burnt up on the exhaust manifold. My son loves being involved in working on this car. He also changed a few hydraulic lines on my tractor I was very proud of him he will be a much better mechanic than I am that's for sure.
Old Aug 7, 2018 | 05:02 PM
  #436
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Dropped the T56 I'm swapping into my IROC off at Pro-Force Performance for a full rebuild, and bought a bunch of T56 stuff from Summit Racing.
I'm anticipating doing the swap in about a month.
Old Aug 7, 2018 | 07:03 PM
  #437
nhgator's Avatar
Car: 1985 T/A
Adjusted the choke a little on my new Sean Murphy Induction Quadrajet and drove to the parts store to get calipers for the daughters Mitsubishi Outlander.
Old Aug 7, 2018 | 07:31 PM
  #438
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I finally got the timing close enough to fire my 383 stroker and have it idle on its own, had to shut it down after a few seconds because its open headers currently and my cry baby neighbors were outside. started hearing a drip sound from underneath the car and noticed a bunch of coolant dripping out of the torque converter dust cover. after twenty minutes of thinking it was a freeze plug behind the flex plate and wanting to die I was able to trace it to the temp sender unit in the head, It was hand tight lol.
also noticed the trans cooler lines are leaking where they go into the trans, they're brand new braided stainless ones from summit so I'll have to check the adapter fittings. does anyone use any kind of thread sealant on these? I understand not to use them on the flared connecting but what about the pipe thread connections?
Old Aug 19, 2018 | 10:41 PM
  #439
Evilokc's Avatar
Engine: tbi 305
I noticed there was a tapping when I turned. it was coming from the rear of the car. it sounded like something hanging and swing back and forth and hitting the inner fender.i popped the hatch and opened the covers to see if there was something inside that was doing it. nope. climbed under it and didn't see anything. finally I pulled the inner panel out all the way and looked down into the rear quarter. it was full of water ( its been raining for weeks here). there was a small reflector floating in it. the reflector was tapping up against the quarter when I turned. I didn't see a drain hole. I got my drill out and drilled a drain and watched about 1/2 a gallon drain onto my driveway. so fixed that! im driving a lot more than I was in the last year. I think the extra miles are taking their toll on my already worn out suspension. im planning a pretty extensive suspension rebuild/ upgrade but im not sure when it will happen. hopefully before stuff starts falling off.
Old Aug 22, 2018 | 09:17 PM
  #440
Evilokc's Avatar
Engine: tbi 305
I went to orileys today to get a new transmission mount. I asked for one made in the U.S.A because ive read people have had issues with inferior Korean rubber. they didn't have one made in the U.S.A so im going to order on eonline
Old Aug 24, 2018 | 06:27 PM
  #441
rburrow87's Avatar
Car: 1975 Pontiac Firebird Formula 400
Engine: SBC 350 w/Pro-Flo 4
Transmission: M29 T56
Axle/Gears: Stock 10 bolt w/3.42 and new Auburn
Did this over the weekend and a couple of days ago, but I finally fixed the driveline vibration! Ordered a "T-56 specific" aluminum 3.5" shaft from Midwest Chassis and had to wait a while to get it (yokes were backordered), but it was worth it. I was previously using a 4th gen aluminum shaft but it would start vibrating at 70 MPH and then buzz the car apart at 75+. Original steel one was way worse and started at lower speeds. Tried a UMI adjustable torque arm to set the pinion angle parallel with the powertrain, flipped the driveshaft a few times on the pinion yoke, tried both poly and rubber trans mounts, and none of that really helped. Trans was rebuilt for other issues and that didn't help either.
The final setup with no noticeable vibration is the new driveshaft, setting the pinion/trans angles to a "broken back" or W configuration, and going back to the rubber trans mount. I ran it up to 85 or so and I couldn't feel any driveshaft vibrations, just the preexisting wheel/tire chassis shake.
Old Aug 24, 2018 | 06:53 PM
  #442
ULTM8Z's Avatar
not a third gen, but I upgraded my 2nd gen to an AD244 alternator...
https://www.thirdgen.org/forums/electronics/755380-ad244-conversion-took-plunge.html
Old Aug 24, 2018 | 07:04 PM
  #443
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Drive it like I stole it on my way to look at a C4. Which was junk- a no go.
Old Aug 25, 2018 | 08:55 PM
  #444
rburrow87's Avatar
Pulled one of the heads to investigate a one cylinder low compression issue... looks like a botched valve job. The guide and/or valve stem is pretty sloppy now too. Just built this engine in April this year. I see signs of the exhaust valve to the right beginning to do the same thing.
Old Aug 25, 2018 | 09:04 PM
  #445
Car: '89 'ROC
Engine: 5.7L
That’s funny man- ditto a few weeks ago. Been gunning for a 6spd with the sawblades’n’LT1 but without the PSairbag for awhile. So ‘92/93. This got snagged right before I showed up. Anyway not the forum for this :P ...
Old Aug 26, 2018 | 06:24 PM
  #446
88IROC-USA's Avatar
Car: 1988 IROC-Z
I'm lookin to wrap up the intake RnR.
Old Aug 26, 2018 | 07:05 PM
  #447
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Had to replace the starter since the cone broke off somehow. I went with a Proformance starter, much easier to get in place with headers.
Old Aug 26, 2018 | 07:16 PM
  #448
DirtyDan's Avatar
Car: 1992 Camaro RS
Removed front fenders, hood, bumper and side skirts.
Old Aug 26, 2018 | 07:59 PM
  #449
Evilokc's Avatar
Engine: tbi 305
why? what you up to man?
Old Aug 26, 2018 | 08:03 PM
  #450
DirtyDan's Avatar
Car: 1992 Camaro RS
Finally getting around to working on my car. All the panels needed replacing anyway so took them off so I could get to everything easier. Gonna have to work on a few things but not sure what yet.
