Car died while making u turn...Help!
Old Jan 2, 2002 | 12:15 PM
91RedFire's Avatar
I just started my car and I was taking it to the car wash that is about 3 miles away from my house. I was making a u turn to get to the car wash when the whole car just shut off. It started again when I put it in park, but what could this be?
I just put on a 3" cat back exhaust, I don't think that would make it stall like that. I have replaced the fuel filter and spark plugs. Could this be a bad fuel pump? Any help is appreciated.
Old Jan 2, 2002 | 01:00 PM
91RedFire's Avatar
I also noticed that it takes about 2 cranks to get my car to start. I tun the key, and that's all I hear is a "Click" I know that is my starter, but could these problems be related?
Old Jan 2, 2002 | 01:08 PM
firbird's Avatar
well first off how much fuel did you have in your car? and second your starter should not affect anything when you are driving.
Old Jan 2, 2002 | 01:27 PM
91RedFire's Avatar
The car had a full tank of premium gas. I have been feeding it premium since I've had it, so I don't think its the injectors either.
Old Jan 2, 2002 | 02:29 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Sounds fuel rrelaed...Starvation of the lines during a turn...Check your fuel pump relay, and fuel pump...Some of the other guys would have more knowledge car specific...I am stil used to my 4th gen...
Old Jan 2, 2002 | 04:01 PM
91RedFire's Avatar
Well I called my mechanic and he said to run some fuel injector cleaner through my fuel system. I did this about 3 months ago, but I guess I will do this again. But if this doesn't work, what else do you think it could be, because I don't want to stall in the middle of the road again and get hit
Old Jan 2, 2002 | 06:02 PM
Little GTA's Avatar
Has it ever done this before?
I would suspect the IAC valve, or some sort of idle situation. If you came to a quick stop your IAC may have overcompensated.
You could try cleaning it to see if that helps.
Was car warmed up good?
Old Jan 2, 2002 | 06:24 PM
91RedFire's Avatar
The car wasn't warmed up at all as a matter of fact. I just drove it after sitting for the night. Could this be something because it was cold?
Old Jan 2, 2002 | 10:29 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
My car will do the same thing if the car isn't warmed up properly..It will either stall or hesitate if I try and drive it when it's really cold. I'm suspecting a fuel problem myself. Most likely a bad fuel pump or fuel pump relay.
Old Jan 3, 2002 | 02:25 PM
91RedFire's Avatar
How would I fix the fuel pump relay?
Old Jan 3, 2002 | 06:33 PM
rondubbs's Avatar
did you get any codes??? when my fuel pump relay went i got a code 54..
replacing it is easy, its one of the relays on the driver side firewall., cost like 10 bucks..
Old Jan 3, 2002 | 08:51 PM
91RedFire's Avatar
I think me and Cobrkiller are having the same problems. I haven't got any codes yet, so I will probably just wait until my car dies, because then I will know exactly what the problem is.
Hopefully it won't be on the wrong side of town
Old Jan 6, 2002 | 04:38 PM
91RedFire's Avatar
Does anybody know what could be causing this? I put the injector cleaner in, my injectors are fine. I know that this is probably a fuel problem because it just happens when the car is cold, but what is it?
Old Jan 6, 2002 | 11:07 PM
I'm going to replace my fuel pump relay and see what happens. My SES light will come on but only If I get on it a little bit then I let off it will come on sometimes(usually on the highway)..Then the car seems to limp home after that. And it acts like it's hurting for fuel and the temp will start to go up..Most likely a seperate problem but I'm going to try replacing the relay and seeing what happens.
Old Jan 7, 2002 | 02:20 AM
Gta-Paladin's Avatar
Do you have pully's ? Maybe your power steering was drawing a lot and you died because of that
Old Jan 7, 2002 | 04:53 PM
91RedFire's Avatar
Nope, I don't have pully's. A friend told me that it moght be my fuel regulator. It looks like I will take it to the mechanic again and see what he says.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
