Oil pressure switch and sender, AC Delco part numbers?
Old Oct 12, 2017 | 02:37 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I'm a little confused.
What are the correct part numbers for the oil pressure switch and oil pressure sender for an '85?
Thanks!
Old Oct 12, 2017 | 02:44 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Oil pressure switch and sender, AC Delco part numbers?
ACDECOD8032 #19106970 Single Bade. Just put one in my 85 WS6.
ACDELCO G1807 #03815936, 3815936 Single Blade. Just put one of those too in my 85 WS6
Old Oct 12, 2017 | 02:52 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Bob!
Who's got the number for the sender?
chazman's Avatar
Axle/Gears: BW 3.45
Oh, BTW, why'd you replace yours, was it leaking?
Old Oct 12, 2017 | 02:55 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
LEAKING wasn't the word. See my edit above. It was soooooooooooooo bad, I thought the rear main seal was completely gone...the way the oil runs down the back. They were not bad, but I changed them both and fixed the leak
Old Oct 12, 2017 | 02:56 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Both of yours at the rear intake, right?
Old Oct 12, 2017 | 02:59 PM
chazman's Avatar
Axle/Gears: BW 3.45
Yup!
chazman's Avatar
Axle/Gears: BW 3.45
Any tricks to getting back there?
Old Oct 12, 2017 | 08:05 PM
Drew's Avatar
Pull the intake? *snicker* Mostly kidding, but I will say they're easy(er) to access when the intake is off.
Old Oct 12, 2017 | 08:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Snall hands, but can be done. Takes time.
