Wierd problem
Old Dec 15, 2017 | 06:04 AM
AJ Case's Avatar
Wierd problem
Hi all,
I have a little problem with my 1990 RS 305.
I have disconnected the tach wire from coil. When I start the car the tach will read 1000 and run and drive just fine. As I drive the tach will start going up. When it hits 4 grand you cant give it more gas or it will bog down. When it hits 7 grand you will have to pull over and turn car off. You can restart it and it starts all over again.
I hope someone has an idea what this is.
thanks
Old Dec 15, 2017 | 08:56 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Wierd problem
If you disconnected the tach from the coil and the tach still reads then you may have disconnected the wrong thing.
So is the car running itself to redline?
Old Dec 15, 2017 | 11:31 AM
AJ Case's Avatar
Re: Wierd problem
I know it is the tach wire I disconnected form coil.
The tach doesn't work like tach more like ohmmeter.
thanks
RallySport92RS
Jul 8, 2002 12:28 PM
86IROC305
Aug 17, 2001 09:50 PM
Deimos
Jul 13, 2001 05:33 PM
91RamAir Formula
Nov 23, 2000 02:37 PM
'91RSS
Jul 31, 2000 06:28 PM
