Wierd battery problem.....
Old Aug 10, 2001 | 11:38 PM
86IROC305's Avatar
I've owned my car for over a year now and never once had any problems with my charging systems, until today. I got off work today and parked my car at my house, about an hour later I went to go to the store and the battery was completly dead!
Nothing was left on and now the dome light barely comes on. I tried to charge it/jump it and it wont hold any charge.
What could have caused this ? I've never had a battery go out like this.... Thanks
86 TPI 305 Iroc-Z
700R4 (rebuilt)
9 Bolt Rear Disc Swap
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Aug 11, 2001 | 11:00 PM
DaveV85iroc305TPI's Avatar
I had a Dodge Caravan that did the same thing. Everything fine and then all of a sudden dead, and won't charge. I replaced the battery and never had another problem. I didn't think batteries could die that fast either.
Old Aug 12, 2001 | 09:17 PM
oneslowV8camaro's Avatar
Yeah, I would say you need to replace the battery because it sounds like it shorted itself out internally. I've experienced this to only mine went dead in about 5 minutes.</p>
Old Aug 12, 2001 | 10:05 PM
RallySport1992's Avatar
That same thing with the battery just happened to my uncle, his battery just died. No way to explain it, it just died. The only thing you can do is go out and get another one.
Old Aug 16, 2001 | 06:50 PM
nj88v6's Avatar
This happened to me too... I replaced the battery, but found that it did it again! So I replaced the alternator, and cleaned the battery cables at the battery and the block, and started of build-up from when the car was built, and now I have no problems with a dead battery.
Old Aug 17, 2001 | 12:32 PM
Stoopalini's Avatar
Replace it, it's bad.
You didn't do anything to cause this, it's just the 100+ deg temps we've been having lately.
I replaced my battery last week, and there were 5 other people in the store at the same time to get batteries. I asked the counter guy what was up and he told me that the day before, he sold 30 batteries! He said the heat is killing them, and I believe him.
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip / MSD ignition
Headers - 3" Cat'Back - Flow Master - dual chrome tips
Adjustable Coni shocks & struts & 16" factory wheels
Old Aug 17, 2001 | 07:37 PM
86IROC305's Avatar
I replaced it tuesday and havn't had a problem since, so I guess It just died. Thanks anyway
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
[This message has been edited by 86IROC305 (edited August 17, 2001).]
Old Aug 17, 2001 | 09:50 PM
rezinn's Avatar
My battery died two days ago, it was three months old. I got a new one under warranty.
Hmm.. heat killing a battery.. I don't see how that could happen, its always hot under the hood when the car is running.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
lanceflame44
Sep 25, 2015 12:28 PM
