cylinder fire issues
Old Dec 27, 2017 | 02:34 PM
staplerplease's Avatar
2007 Pontiac g6 4 cylinder, third cylinder not firing, replaced plugs/swapped plugs, checked and swapped coils,checked wiring, checked and swapped fuel injectors/checked wiring, problem stays with that one cylinder, looked down at the piston head, looks like a lot of carbon build up and a little sludgy. the other cylinder heads are not sludgy but do have carbon build up, could the intake be that dirty causing this issue ?
Old Dec 27, 2017 | 07:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: cylinder fire issues
This is a forum dedicated to 1982 through 1992 Chevy Camaro and Pontiac Firebird cars only . Your best bet would be to find a forum that deals with your type of car and ask there . As a generalized statement I will say , "sludged up and wet" is not a good sign and I'll bet a compression check is gonna tell you all kinds of bad things about that sludgy cylinder .
Good Luck with it .......
So exactly what part of my post did you not understand ?
In your other post yesterday about the same off topic car , I posted the above response . Now I promise you , you can post in every sub forum on the page and the answer will still be the same ;
GO FIND A FORUM DEDICATED TO YOUR CAR !
Old Jan 1, 2018 | 05:38 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
The third cylinder isnt firing, and this is third gen. That's the logic for the registration and posting here lol
babybear82lilj
Feb 5, 2008 05:12 PM
jackballs529
Jan 18, 2005 08:42 PM
86LG4T56
Jul 23, 2004 10:08 PM
pontiacpete
Jul 20, 2003 01:32 AM
