smog delete
Old Dec 31, 2017 | 09:27 PM
ssx2james's Avatar
Car: 1990 iroc
Transmission: auto
smog delete
my 90 iroc with a 350 had the ac compressor lock up, so a shop deleted it and put a bracket with a pulley. now the car can be driven. now i had the cooling fan not wanting to turn off so took back to shop. they discovered that the smog pump had been removed by previous owner. they put on a pulley in that spot, but with no bracket. do they sell a bracket to put there or will my current setup hold. car has a serpentine belt.
Old Jan 1, 2018 | 12:45 PM
GeneralDisorder's Avatar
Re: smog delete
GM made some Canadian models without smog pumps:
Amazon Amazon
GD
Old Jan 1, 2018 | 03:41 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: smog delete
W.E.G.'s Avatar
Engine: V6 2.8
Re: smog delete
http://www.hawksmotorsports.com/cama...delete-pulley/
Old Jan 1, 2018 | 09:03 PM
ssx2james's Avatar
Car: 1990 iroc
Transmission: auto
Re: smog delete
the bottom pulley was the one they put on but there is no bracket in between there. will that bolt hold.
Old Jan 2, 2018 | 11:54 AM
Re: smog delete
Lots of factory idlers are done that way. I wouldn't think it will be a problem. But you can actually just delete it entirely and route the belt differently if it scares you.
GD
Old Jan 2, 2018 | 10:09 PM
ssx2james's Avatar
Car: 1990 iroc
Transmission: auto
Re: smog delete
if the belt is routed differently does it cause the water pump to spin the wrong way? shop said something about clockwise vs. counterclockwise?
Old Jan 2, 2018 | 10:55 PM
Re: smog delete
Not an issue. This link details all the options:
http://sethirdgen.org/serpentine.htm
GD
Old Jan 3, 2018 | 12:29 PM
Drew's Avatar
Re: smog delete
Seeing as how the A/C compressor is likely the highest load on the belt drive system, and it's been deleted, it's probably OK.
Personally I'd run either of the two GM delete pulleys available, or just run a shorter belt from the A/C delete to the crank. Any of those three options beats throwing a generic pulley onto a mounting ear that's not really intended to take that kind of stress.
Old Jan 3, 2018 | 01:44 PM
Re: smog delete
I have the smog delete pulley on my serp setup and it works great. Personally it looks all lopsided if you don't have a pulley there. But functionally it's the same. Dealers choice.
GD
Kblakney
Sep 21, 2016 10:03 AM
hookin88formula
Aug 15, 2008 09:44 AM
Zepher
Jul 23, 2003 10:18 PM
CamaroEFI
Jun 9, 2003 03:08 PM
