383 v 383
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
383 v 383
looking at a newer stronger engine and although like the 408,s ,427,s these guys can build better motor than me.. and turn key no more worries.
i have nowhere to build a motor and am not a pro but have no issues maintaining it.
It all comes down to what i need ,, a good car to drive and a strip car 2 nights a month..
1 this good engine
https://www.cnc-motorsports.com/sb-c...-hp-59315.html
2 this good engine
https://paceperformance.com/i-134750...te-engine.html
both simmilar prices and simmilar power and capable of 11.5/12.5 et,s all night
1 this good engine
2 this good engine
Axle/Gears: 4:10
Re: 383 v 383
Please consider including Blueprint engines and/or ATK into your decision matrix. Both companies dyno test prior to shipment. If you're a Veteran? Blueprint has a unpublished 10% discount!!!!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 383 v 383
i wont get into chinese cranks and rods..thsts another story...i am focused on a dependable $6500 engine..
Car: 84 Z28
Engine: 383 Stroker
Re: 383 v 383
I know BRE has sale engines sometimes.... just to move them.. I see posts on fb from time to time...
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 v 383
Make sure they can ship to Australia
Do you not have a good builder in your area? You have a good auto scene
Re: 383 v 383
engines here have imported bits so up goes the cost..
a good engine here costs $15,000 ,,but will run at 6500 all day if needed..
even a 6000rpm 383 to 427 will cost $14,000 iffbrand name top line parts used,,
i have an importer in cal thst brings 3 shipping containers a month to australia
Re: 383 v 383
