V belt to Serp system
Old Feb 1, 2018 | 11:58 AM
321GO!'s Avatar
I want to convert a 85 v belt system I want to convert it to a Serp system from a 90 z28 that I got from the junk yard what all do I need to get this to work the 85 is a sbc with a mechanical fuel pump will the fuel line get in the way An how would I wire the alternator
Old Feb 1, 2018 | 05:38 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: V belt to Serp system
The fuel line is a problem. If you can borrow flaring and bending tools, it isn't a big deal.
The wiring needs extended to the alternator and a different plug end, along with an in-line resistor if you have a volt meter.
Get All factory braces for support. Parts can come off an 88-93 Caprice too.
Old Feb 1, 2018 | 05:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Here is the cs wiring pigtail needed.
https://m.ebay.com/itm/GM-Delco-CS13...YAAMXQvTlRf1Qc
On the passengers side head there is not a provision for the stud for mounting the ac bracket.
Old Feb 1, 2018 | 06:58 PM
321GO!'s Avatar
I have a steel braided Edelbrock fuel line I need to find a 88-93 caprice for the header braces does power steering hook right up? An I don’t have a volt meter do you think I still need the resistor?
Old Feb 3, 2018 | 05:01 PM
jmd's Avatar
jmd
An idiot light acts as the resistor, so if your gauges include one that is functional , you should be able to skip the resistor. Keep in mind, this helps trigger the alt. to charge.
Power steering lines should work without issue.
Of course, the water pump must be changed.
Old Feb 3, 2018 | 06:53 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
You didnt mention the fuel injection of the 85. If its TBI then the truck ones may work as well. but i assume the 85 is TPI right
Old Feb 4, 2018 | 05:51 PM
321GO!'s Avatar
It’s a carbrated sbc 350 it was a tbi originally
Old Feb 4, 2018 | 05:52 PM
321GO!'s Avatar
okay cuz the alternator wiring was bothering me I had no idea about it
Old Feb 4, 2018 | 06:44 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Ok in that case if you dont have the TPI throttle body to contend with and you cant find z28 brackets or whatever, the truck TBI ones will line up. They will sit a little closer to the engine, maybe an inch.
Old Feb 8, 2018 | 11:14 PM
321GO!'s Avatar
I got the ones From a tpi car I think it was a 89-90 car
1992Vortec
Nov 22, 2014 12:22 AM
midge54
Feb 2, 2014 05:25 AM
1RedCamaro
Nov 3, 2010 12:30 PM
neverdone
Jul 31, 2008 06:43 PM
57TUNED
Aug 3, 2007 07:25 AM
