So, who makes a decent MAF?
Old Feb 21, 2018 | 09:22 PM
KanzlerBismarck's Avatar
Car: '89 Iroc 5.7
Axle/Gears: G80 Posi/LS & GH3 2.77
So, after tearing *** around town today, I stopped at the post office, went to fire up the IROC and it idled rough.. then died. I kept firing it up, gassing it a bit but it would just start to die again. I finally got it to start and run after about 6 trys and she got me home just fine (About 4 miles up the road). But when I went to start it back up it sputtered and took another crap. I checked the fuel pressure and she is at a bit over 40 psi at the rail. I tried unplugging my MAF and it ran rough for a bit.. then it settled and the check engine light came on and it smoothed out (As I understand it the ECM kinds estimates when in this mode). Anyway, I plugged it back in and it's back to taking a **** again.
I am going to try swapping out the MAF sensor based on this troubleshooting (Oh also... My injectors are only about 3000 miles old)... but I am having an issue finding one I trust...
On one had you have some for like.. 75.00 on fleabay. Over at Autozone and O'Reilly's they have them... but they get **** reviews. Then there is a 75.00 unit from Hawks.. but it is used (Although guaranteed to work on start up).
I found an original.. but they want an arm and a leg for it (Like 350.00).
I am thinking the Hawk's unit... but before I pull the trigger... do you guys have a good source for these?
Old Feb 21, 2018 | 09:56 PM
Abubaca's Avatar
Re: So, who makes a decent MAF?
-Sent you a PM
Old Feb 21, 2018 | 10:13 PM
Car: '89 Iroc 5.7
Thanks for the heads up!
Old Feb 22, 2018 | 07:52 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
I want "in" too. Don't hold out...
Old Feb 22, 2018 | 04:14 PM
Drew's Avatar
Rock Auto lists the Spectra Premium MA-157, which in the pics looks to be the same as the Wells SU-145. Haven't heard much about the 'Wells' MAF lately, but it was a popular upgrade 15 years ago. It's a more modern design, that flows better than stock. Not an endorsement, I've got one but haven't gotten around to putting it on the car yet.
http://www.rockauto.com/en/moreinfo.php?pk=6284301
Old Feb 22, 2018 | 04:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
@Drew , do you know if this has a burn off circuit or does it throw a code 36 for the lack of a burn off ?
Old Feb 22, 2018 | 04:50 PM
Drew's Avatar
IDK. Google "thirdgen.org wells maf" and there are a lot of threads in the early 2000's. By all accounts it's a direct plug and play substitute.
https://www.thirdgen.org/forums/tpi/...ml#post3590049
Old Feb 22, 2018 | 05:31 PM
Engine: Lb9
Transmission: M20
Thanks for the link very informative.
Old Feb 22, 2018 | 07:18 PM
Car: '89 Iroc 5.7
Interesting...
https://www.oreillyauto.com/detail/s...t/camaro?q=MAF
Seems to be the same one they sell at Oreilly's.
Old Feb 22, 2018 | 07:31 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
I see you're wisely avoiding a ripoff already but just the same from my reading: avoid the Granatelli.
Carlos773
Jan 25, 2011 07:14 AM
Grumpy
Dec 29, 2004 05:50 PM
89ROC
Apr 2, 2002 07:21 PM
86TpiTransAm
Jan 26, 2001 09:48 PM
