Gas mileage all over the place
Old Mar 17, 2018 | 05:51 AM
Bluegoose95401's Avatar
Ok so my gas Mileage is all over the place when I first got the car i went three tanks at a steady 30 miles a gallon then it dropped to 25 then the next tank was 15 then the next was 13 then the next was 12 tonight I went and filled up it was back to 26 mpg. Just did cap rotor wires and plugs ( old plugs looked fine little brown like a lightly toasted marshmallow ) . Do you think it’s the quality of gas usually I get 91 octain from rotten Robby but do you think i would be better off with 87 or getting gas from chevron. Or even 91 octain from chevron?? Possibly somthing else like a clogged catalytic converter. It’s a 3.1 90 bird sorry for the rambling.
Old Mar 20, 2018 | 08:28 PM
JA411's Avatar
Re: Gas mileage all over the place
Use a quality 87. Compression is not high enough to support higher octane. It will just cause unburnt fuel, excess carbon build up, and even get into spark knock with the carbon. I have a 2nd, 3rd and 4th gens. The V6's work best on 87!
JOE
Old Mar 20, 2018 | 09:04 PM
Sounds like a leak. Filler neck would be the obvious first place to look.
Frued1961
Sep 30, 2017 09:38 AM
Randy82WS7
Alternative Port EFI Intakes
Mar 16, 2007 12:32 PM
pvt num 11
Pacific Region
51
Jul 27, 2004 05:19 PM
redrummer
Jan 13, 2004 04:48 AM
irocbsa
Jan 25, 2001 04:30 PM
