Sensor Issue 1984 Caprice 305 quadrajet
Car: 1984 Caprice Classic
Engine: 305 quadrajet
I have an 84 caprice with a quadrajet that is throwing a code for an Intake Air Temp Sensor (low temp detected error) which carb engines do not have said sensor, what else could be causing this code ive been trouble shooting the electrical and all the temp sensors are working
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Sensor Issue 1984 Caprice 305 quadrajet
This is a thirdgen f body forum. You might be looking up the wrong error code for your year.
https://www.troublecodes.net/gm/
by that chart it says its a MAT circuit code referring to the intake manifold but i cannot find any sensors located on the manifold
Engine: Lb9
Transmission: M20
You do t mention the code number but here is a list for ccc.
I don’t think there is a mat/iat.
http://www.early3rdgen.com/forum/viewtopic.php?t=25
Engine: Lb9
Transmission: M20
23. MCS, the MCS is open or grounded, check all wiring and connections, adjust or replace MCS.
thank you for pointing me in the right direction i had a feeling the carb would be needing rebuilt soon to begin with
Engine: Lb9
Transmission: M20
If you have a service manual it might give the ohm spec for the solenoid. This way you might illuminate the wiring as a issue. I’m not sure but going into diagnostic mode might command the mc solenoid.
Car: `86 SS / `87 SS
The MC solenoid very rarely fails. The code 23 can be set by reasons other than outright failure.
The codes from the ECM are the same as a 4BBL 305 third gen through 87.
84_Cruiser
Jun 17, 2012 03:53 PM
firebirdta84
Jun 1, 2012 03:18 PM
GMP318
Carburetors
May 13, 2007 01:41 PM
