MSD 6AL BOX LOCATION
Old Jun 12, 2018 | 09:01 PM
bczee's Avatar
Car: 84' Z28
Engine: L69
i had originally mounted my MSD 6AL box where my Charcoal Canister is. I have had to replace the Charcoal Canister now and looking for new location to mount my 6AL.
Where have you guys mounted your MSD 6AL box ?
I have a 1984 Z28 L69 engine/T5.
thanks for the input.
BC
Old Jun 12, 2018 | 09:13 PM
Drew's Avatar
Re: MSD 6AL BOX LOCATION
In the trash can where it belongs. No, actually I've kept mine in a box in the closet for at least a decade, probably a decade and a half now that I think about it... Aside from no good place to mount the thing in a thirdgen, I haven't really seen any reason to mess with it. Just one more thing to potentially fail.
Old Jun 12, 2018 | 09:38 PM
bczee's Avatar
Car: 84' Z28
Engine: L69
Once I installed it. idle improved as well as gas mileage..this was 14 years ago. So.. the question still remain for a useful reply from someone who has mounted one.
thank you
BC
Old Jun 12, 2018 | 10:04 PM
Boom's Avatar
Car: 1986 Iroc
Engine: 383
I'll try and get a better picture tomorrow. Mine is up behind passenger valve cover on firewall.
by https://www.flickr.com/photos/62639173@N03/, on Flickr
Old Jun 13, 2018 | 09:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Hidden in the battery where it belongs. Being its a MSD product, I have it setup to be bypassed quickly if I suspect a failure. (Been through about 5 or so)
Old Jun 13, 2018 | 10:33 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
That's an awesome hiding place, in a fake battery!!
Old Jun 13, 2018 | 11:05 AM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
I have used an MSD 6xx box on all mo hot rods since the 80s. I continued to buy because it keeps the spark plugs clean and improves idle quality. I've had only one fail and it got fried because the voltage regulator failed and I didn't have a fuse between the MSD and the battery. I have a non-A/C car and mine is mounted in the same place as Boom's. You might be able to mount it under the battery or charcoal canister so that it is out of sight.
Old Jun 13, 2018 | 11:43 AM
Abubaca's Avatar
Mine is also located right there on the firewall by the blower box. I've never had any issues with it, but deep down I also know it's not necessary. I can bypass it literally in 60 seconds if need be.
.....as for idle....what kind of engines are you guys running that you had idle issues in the first place!?
Old Jun 14, 2018 | 12:25 AM
bczee's Avatar
Car: 84' Z28
Engine: L69
Thanks for all of the reply's.
Boom - I have a AC car so.. the Firewall is too full to attempt putting anything else there.
I might try to build a mount/tray for placement on top of the Canister.. but I think the Air intake tube is restricting the combined height of the Canister and the MSD Box.. Under is the Vacuum reservoir.. so that is out.
Might look under the battery tomorrow as them might have some room. Or look in the dash.
TTop350 - Great idea on that Battery box !
BC
Old Jun 14, 2018 | 09:49 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I mounted mine on the relay bracket between the master cylinder and the fender. Fits perfect.
Old Jun 14, 2018 | 10:01 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Did you mount the battery in the spare tire spot? What bracket did you use, or did you fab one?
Old Jun 14, 2018 | 03:39 PM
BOTTLEDZ28's Avatar
Transmission: A4
Mine is mounted in the landfill. I used to run MSD products back in the day but soon realized that they fail quite a bit.
In my opinion, a properly running OEM HEI ignition system is more than capable of running stock to mildly modified TPI engines.
Old Jun 15, 2018 | 06:36 AM
TTOP350's Avatar
The world may never know!!!!
Old Jun 15, 2018 | 08:29 AM
BOTTLEDZ28's Avatar
Transmission: A4
I had a 97 WS6 with a hidden nitrous kit. The fuel, nitrous and purge solenoids along with the RPM window switch and fuel pressure safety switch were all mounted inside a gutted out Delco battery. I ran the actual battery inside the spare tire area with the bottle. Yes, there was a plate separating them. No one had any idea the nitrous was there. Remote bottle opener and heater switches along with a pressure gauge were mounted inside the center console. It was a WOT setup so the micro swtich was mounted on the TB which had an OEM cover on it.
Dont ask how I gutted out a battery and disposed of the contents.
Old Jun 15, 2018 | 03:24 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
PO moved the relay bracket from the firewall to the top of the wheel well. The 6A fit right at the top corner of the firewall.
See post 109.
https://www.thirdgen.org/forums/tech...irebird-3.html
Note that's manual brakes so easier to see.
Old Jun 15, 2018 | 06:36 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Ha! I have a few friends that had issues with MSD ignition boxes dying. So genius me buys a MSD digital 6 box. It's two years old, about 4000 miles on it. And guess what? My car wouldn't start today. Bypassed the box and it fired right up.
They better send me a new damn box or repair it.
Old Jun 16, 2018 | 09:38 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I was just given a 6AL for free and was wondering where to mount mine as well. I deleted the AC and am gonna get the ac delete box but I feel like its not a good idea to mount it to the delete box.
Old Jun 17, 2018 | 11:30 AM
Abubaca's Avatar
Mine has been on the ac delete box for about 15 years with no issue. I've heard the newer boxes don't last, and experience seems to prove that point.
Old Jun 17, 2018 | 12:06 PM
skinny z's Avatar
Bent up some aluminium sheet into a platform that fits over the charcoal canister.
Old Jun 18, 2018 | 03:01 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Well just got off the phone with MSD. Even though the box is two years old with very little mileage. I was told it's out of warranty and they're not going to do anything for me. Now I'm waiting for the repair department to take my call. Which clearly they're going to charge me for. Garbage product with garbage customer service. $385 box that's going to last two years? Sign me up, what a great product!
camaro1122
Jul 24, 2011 03:18 PM
Hole-Shot
Mar 3, 2010 07:06 AM
neagan
Dec 27, 2006 06:41 PM
Steve86TA
Nov 24, 2006 08:02 AM
