V-belt Help
Old Jun 13, 2018 | 08:20 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
V-belt Help
I'm trying to get my A/C back up and running. I've replaced everything, its all new. However I'm having problems with the belts. My motor is a 350 out of a 1980-85 Chevy truck. I've done some research and it seems that the stock 305 in my TA which I never saw nor do I have came with a 3 groove crank pulley. Is this true? I've eliminated the air pump so no need for a 3 groove water pump pulley. Can someone chime in with some advice or possible picture of the factory v-belt set up?
Old Jun 14, 2018 | 10:54 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: V-belt Help
Old Jun 14, 2018 | 05:53 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: V-belt Help
Hey Marc,
Nice to see you in Atlanta! So in that bottom picture, looks like you need a long belt that goes around the A/C, Water Pump, Crank & P/S as well as a second belt around the crank and P/S. Looks like you will need a 3-groove pulley for that larger outer belt. I used the pulleys off my 305 on the 327 and the crank pulley is a 3-groove and I too had A/C, Air Pump at one time!
Old Jun 15, 2018 | 10:10 PM
Car: !982 Trans Am
Axle/Gears: 3.08
Re: V-belt Help
Thanks Bryan, on the hunt for a 3 groove pulley. I may have a line on one tomorrow. Have a good evening buddy.
94-6spd
Jun 19, 2019 06:05 PM
sflthndrckn
May 15, 2019 02:10 PM
nemanracing
May 9, 2006 01:02 PM
1989karr
Dec 19, 2005 01:02 PM
blue86iroc
Aug 15, 2002 10:06 AM
